Cold air intake- mud??
RE: Cold air intake- mud??
Wouldn't a 'snorkle' modification make more sense for you?
The CAI is not going to give any performance gain in the low rpm engine operation that a skilled off roader is going to do.
Don't put a CAI on your truck that does not protect as well from mud/water
....unless one of the CAI manufacturers offers to pay you endorsement money of a suitably large amount.
I usually don't disagree with Hank, becuse he packs a ton of good information that I enjoy reading.But on my personal experience, skill not withstanding....the above statement may not be true.
If you're in low range, with decent gears, and dependent on the terrain....and thats the kicker...you may find your self using a pretty fair amout of rpm. Perhaps the term "low speed" may be a better description.
Generally I am taching about 2500 rpm to climb a loose rocky slope, a hill climb in dirton a steep grade might bounce me off the rev limiter.Yet I may never exceed 15 to 20 mph!
Sand requires horespower, and anything you can do to add it makes sense.
To pop over a two foot ledge requires more skill (and traction) than horsepower. To crawl through 50 feet of moguls made from lava rockrequires a flexable suspension.
Mud is much like sand...but add water. It goes everywhere even when the fan doesn't fling it.
Since you asked what kind of CAI to use, I'll base my choice again, on experience. I would NOT waste my money on a K&N! I would use an Airmax, Volant, or S&B design. These designs incorporate an Airbox in the factory spotthat isolates the the filter from mud/water and engine heat (and sand to a point) yet flow better with a straight design tube than the factory.
I would also base your purchase on further mods. If you DON'T plan on any more mods, you might want to stick with a drop in Hi flow element. The factory system flows plenty well for a stock motor, and your mods could be better spent on"off road" mods like lockers, gears, suspension stuff, etc.
Trending Topics
