thoughts on winter warm up
Old Dec 9, 2007 | 07:09 PM
  #21
XXL 1500's Avatar
XXL 1500
Default RE: thoughts on winter warm up
it was a joke lol
Old Dec 9, 2007 | 07:22 PM
  #22
ryans590's Avatar
ryans590
figured so lol could go with 0w-30 thow
Old Dec 10, 2007 | 05:43 AM
  #23
HankL's Avatar
HankL
the colder the winter weather you have
the faster an electric block heater and oil heater pays for itself
by giving better MPG in the first 20 miles of driving
one side benefit of the Evans NPG coolant is that it warms the engine up faster in very cold weather by being 'sluggish' and more viscous in the radiator
the coldest I have started my Ram in is 13 below
and the Mobil 1 syn oil let the engine turn over easily
even with a 4 year old battery...but the battery was 1100 CCA
Old Dec 10, 2007 | 09:13 AM
  #24
shott8283's Avatar
shott8283
1100CCA makes a huge difference.. i think the stock mopar battery is only 750CCA
Old Dec 10, 2007 | 10:55 AM
  #25
ryans590's Avatar
ryans590
yah i have 2 1000cca bats in there, and the main is always nice and tosty, its got a bat warmer around it
Old Dec 10, 2007 | 10:58 AM
  #26
scbcman's Avatar
scbcman
THe most obvious reason to let your truck warm up before you leave has nothing to do with the engine, but a lot to do with you....a warm truck is a more comfortable truck!!! THe block heater helps speed things along.
Old Dec 10, 2007 | 12:17 PM
  #27
1500sport's Avatar
1500sport
Do you let it idle in park or neutral? Letting it idle in neutral will let the tranny build up pressure as it allows the fluid to flow. No flow in park.
Old Dec 10, 2007 | 01:57 PM
  #28
robbsclassics's Avatar
robbsclassics
I thought N was the same a as park. The only differance is that it is not locking the output and tires in place. Is this wrong?
Old Dec 10, 2007 | 06:56 PM
  #29
aim4squirrels's Avatar
aim4squirrels
Tranny fluid doesn't circulate in Park. That's why they tell you to fill it and check fluid levels in neutral.
Old Dec 10, 2007 | 08:47 PM
  #30
ryans590's Avatar
ryans590
when ever its sitting idling for a period of time it should be in N not P,
