2WD lo
Old Dec 11, 2007 | 01:01 AM
ryans590's Avatar
ryans590
Default 2WD lo
ive been seeing this around a few sites laitley, about pepole putting in posi lok or a valve to prevent the CAD from engaguing....just courieoud what the advantages yo having 2lo woild be...where it would usefull
.... hmm maby i can use 2lo insted of regering my truck(im joking)
Old Dec 11, 2007 | 01:26 AM
WesV's Avatar
WesV
Default RE: 2WD lo
In all honesty, 2 lo has no real uses outside extreme 4 wheeling and then you are usually more interested in 2wd front axle driving only. I have seen a guy with a CTD dually use 2 low to shift through the first 5 gears and then pull it into 2 high and catch 3rd and go on, but he was WAY over loaded for that truck and not something that should be condoned. The other disadvantage, on the half tons specifically, when you go into 2 low you are effectively doubling the torque applied to the rear, that means twice the torque on the u-joints, driveshaft, diff gears and axle shafts... it is a GOOD way to break things if you aren't judisious in the use of the skinny pedal.
Old Dec 11, 2007 | 01:37 AM
getpower's Avatar
getpower
Default RE: 2WD lo
Posi Lok isnt specifically for your truck to have 2LO, its just another benefit of the product.
What it is for is it takes out the whole vaccum system so you'll never have to worry about your t-case not working b/c of a vaccum problem in the lines. Instead, you now reach down and put the truck into 4x4, and pull the posi lok lever and that is how the 4x4 gets engaged.
If you WANT 2lo, all you would have to do it pull the posi lok lever.
Understand?
Old Dec 11, 2007 | 10:52 AM
ryans590's Avatar
ryans590
Default RE: 2WD lo
yah i know that's not what posi lok is for but i know that's why some people want it
ORIGINAL: getpower
and actually if you want 2 lo is want you do is shift it into 4lo but DONT pull the posi lok cable...
i know how the systems work, just curious what the usefulness of using the truck in 2lo is
Old Dec 11, 2007 | 11:23 AM
lucas3397's Avatar
lucas3397
Default RE: 2WD lo
I would say it would be useful in situations where you needed the low gearing on dry pavement. Like pullin a boat up a ramp and parking it. Or maybe pulling a really really heavy load a short distance as in like around the block or something. I guess just anytime you needed the extra torque but where on solid ground and didnt want thebinding.
Old Dec 11, 2007 | 08:46 PM
ryans590's Avatar
ryans590
Default RE: 2WD lo
hmm i see where your going with that lucas3397i must say ive gone up some real steep grades where i have put it in 4lo but dident need 4wd however i think WesVhas a good point too, 2x more power foing to the rear end, easer to beak stuff
Old Dec 11, 2007 | 10:30 PM
dhvaughan's Avatar
dhvaughan
Default RE: 2WD lo
good for easing around on dirt roads and holding a slow speed w/o the steering difficulty/binding that occurs in 4wd.
good for easing a load of wood up a hill, driveway, yard.
good for pulling a big boat up the ramp.
2 lo has about 2-3 times the torque as 2 hi or 3hi. somebody called it a butt-load of torque.
like someone else said, it eliminates the worry about the fragile little vac lines, whether cad will/won't work when you need it. whether its engage/not engaged when the stupid light doesn't work. instead its a simple, foolproof cable. its engaged or its not and you can see/feel it on the control lever.
Old Dec 11, 2007 | 11:15 PM
ryans590's Avatar
ryans590
Default RE: 2WD lo
whats 3hi lol...j/k
yah is see where it could be usefull but i dont see myself ever needinf it, guss ill just wate for the cad system to grenade then change it out
Old Dec 11, 2007 | 11:18 PM
dhvaughan's Avatar
dhvaughan
Default RE: 2WD lo
ORIGINAL: ryans590
whats 3hi lol...j/k
haha, i guess that's where one of the open diff's is spinning like hell and going nowhere.
Old Dec 11, 2007 | 11:50 PM
nhlbill's Avatar
nhlbill
Default RE: 2WD lo
If you have ever had to pull a boat up the ramp, or tow a friends car a short distance, or back up your camping trailer up your steep driveway, or pull a stump out of your yard etc........2wd low is damn handy.
Since it puts no more stress on any drivetrain components than the factory designed 4wd system does, the "going to break stuff" argument is just rediculous. In fact it is way better on your transmission to properly apply the torque than to lug your drivetrain so it's actually better on your truck. Picture yourself trying to pedal your mountain bike up a steep hill in high gear vs. a low gear....which one is easier on you?
Off road you don't have to be on a goat trail to enjoy it's benefits either. Very often the grade demands more power than your high range can give you without lugging and overheating.
2wd low is a very nice option and can be useful in many situations. To say otherwise is just not an educated statement.
That said though, I would not go out and buy a "posi lock" or hub conversion kit just to get 2wd low. It's just a nice fringe benefit of the posi lock, or in my case the hub conversion.
