Gauge Questions
Old Jan 3, 2008 | 10:30 PM
rabbler's Avatar
rabbler
Default RE: Gauge Questions
I don't understand the reasoning for monitoring the post cat (downstream) o2 sensor.
Is cat efficiency what you want to monitor?
I would think you would want to tap into the pre-cat (upstream) o2 if you want to monitor rich/lean engine conditions.
Old Jan 3, 2008 | 11:25 PM
Silver_Dodge's Avatar
Silver_Dodge
Oops, sorry, just read what I wrote again and it should have said the pre-cat o2 sensor, not post-cat. Wonder why I typed that. The wires I described are still correct for the pre-cat sensor though, so if he followed the description of what wires to use, he is on the right sensor.
Old Jan 4, 2008 | 12:37 AM
chet's Avatar
chet
well **** that could explain alot of ****...haha
Time to go hook it to the front Sensor after i may have friend the rear one.
Silver can you tell me if its fried since it was shorted out ?
Old Jan 4, 2008 | 03:06 AM
chet's Avatar
chet
also i was wondering if you could tell me the wire color out of the four(1 grey, 2 white, 1 black) that i need to splice into at the oxygen sensor not the PCM. I talked to a dodge dealership and they said grey and i tried it and still nothing. The gauge i thought was the easist is turning out to be the hardest.[]
Old Jan 4, 2008 | 09:13 AM
Silver_Dodge
I don't think you fried it, but your splice may have caused the voltage #'s to change, thus throwing the code. Remove your splice, then clear the codes and see if it comes back.
So the wires that are on your a/f gauge are 1 gray, 2 white, and 1 black, is that correct? Or are those the wires on your o2?
Old Jan 4, 2008 | 11:31 AM
sawtooth's Avatar
sawtooth
Don't know if this helps But: from '96 factory manual
"up-stream O2 sensor"
16 gage-dark green with orange tracer---auto stut down relay
18 gage- blackwith white tracer---chassis ground
18 gage- tan with white tracer---PCM signal
18gage- black with light blue tracer---PCM sensor ground
"down-stream O2 sensor"
16 gage- dark green with orange tracer---auto stut down relay
18 gage- black with light blue tracer---PCM sensor ground
18gage- orange with blacktracer---PCM sensor
Old Jan 4, 2008 | 01:10 PM
chet's Avatar
chet
ORIGINAL: Silver_Dodge
K, ill clear the codes and see what happens. Those are the wires on my O2 Sensor, the back of the gauge had something like 1 red 1 blackand 1 yellow 1 green. Where red was switched ignition, black-ground, yellow= Battery+, Green=Sensor input.
Old Jan 4, 2008 | 02:11 PM
chet's Avatar
chet
i have officially tried all 8 wires(4 on each sensor) with short test runs with nothing happeneing. Howver the blacks will peg it to rich and the rest will peg it to lean... I unplugged the + battery connection and my check engine light went away. I also looked for what you described earlier as the PCM and i cannot find it nor can i find the right wires, so a little more explination or possibly a picture would work wonders, thanks.
Old Jan 4, 2008 | 03:44 PM
Silver_Dodge
Mine pegs to rich as soon as I start the truck because it is in open loop mode (warm up mode) until it warms up. Once warmed up (which can take several minutes), the truck goes into closed loop mode (idle mode), and it starts operating normally, dithering with the closed loop fuel trims, or locking into an a/f setting when I get on the gas (back into an open loop mode like full throttle mode). Maybe you didn't let it run long enough to get into closed loop mode.
I'll post a picture of the wires I used, but you'll will have to wait till this weekend.
Old Jan 4, 2008 | 09:58 PM
chet's Avatar
chet
ok i hooked it up to the black one and it works but it jumps around alot. i was wondering if that i normal or if i got the ground that is transferign the signal as it is groudning it?
