Cooling Problems......
Old 12-05-2004, 12:55 AM
OleRed's Avatar
OleRed
OleRed is offline
Default Cooling Problems......
I have a 1996 Dodge Ram 1500 with a 5.2L. It has been heating up on me when I sit in stop and go traffic. I check the coolant level about every 2 days now and it is always Low. I cannot find a pin hole anywhere. I have also checked the system with a tool that applies pressure in to the through connection of the Radiator. I held 15 lbs and did not leak down. My first guess was the clutch fan, but it feels like it has tension when the motor is cold. Where is the coolant going? What is going on with my truck?
Help Please.
Old 12-05-2004, 03:17 AM
Ramtuff's Avatar
Ramtuff
Ramtuff is offline
Default RE: Cooling Problems......
Check you oil and make sure there isn't any coolant in it. Also, you might try replacing your radiator cap since the system held pressure. Caps do go bad from time to time, and coolant can evaporate and escape.
Old 12-05-2004, 02:49 PM
OleRed's Avatar
OleRed
OleRed is offline
I just checked the oil and it looks good, so my head gaskets should be ok right. I also checked around the intake manifold, nothing visual.
I changed the thermostat in my truck to a 170 replacing the stock 195 for cooler temp on the requirments of the JetChip Stage 2. Would the temperature change have any effect on the Clutch Fan?
I will change the cap today.
Old 12-07-2004, 02:42 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
if the cap doesnt fix it, i'd look a the fan clutch. overheating in stop & go traffic is a sign that the clutch is not engageing to draw air past the radiator...
Old 12-22-2004, 02:51 AM
Scootr's Avatar
Scootr
Scootr is offline
My 96 seems to go just above the mid point...even when it's near zero outside. Every few days I get a slight smell of coolant inside the engine bay even though I can't find any leaks. The coolant level seems ok. Also,shouldn't the radiator cap be pretty warm at full operational temperature? Mine is as cool as the outdoors right now when it's running over 200+ degrees. The truck only has 42k on the ticker. I'm I just being parenoid or does it sound like I may have a problem here?
Old 12-22-2004, 10:42 AM
charlie1935's Avatar
charlie1935
charlie1935 is offline
ORIGINAL: Scootr
The cap should hot. From the guage reading, it probably has the stock thermostat in it.
Old 12-23-2004, 04:48 AM
Scootr's Avatar
Scootr
Scootr is offline
The radiator cap should or shouldn't be hot/warm at normal operating temp??
Old 12-23-2004, 12:30 PM
charlie1935
I guess I screwed up trying to post. The radiator cap should be hot to the touch as it contacts the coolant in the rad.
Old 12-23-2004, 03:54 PM
Scootr's Avatar
Scootr
Scootr is offline
I think I may have an issue then...my radiator cap is cool after temp hits 200 degrees. Very strange [sm=smiley24.gif]
Old 01-02-2005, 06:04 AM
HemiMan02's Avatar
HemiMan02
HemiMan02 is offline
if you still have your 195 thermostat...put it back in and see if the problem goes away....if could be that the 170 isnt allowing the coolant to get hot enough for the fan clutch to engage and therefore the temp has to go up when you just sitting there before it will kick on. 25 degrees of change can do funny things
Quick Reply: Cooling Problems......
