Truck Stumble.
Old Jan 10, 2008 | 12:30 PM
chet's Avatar
chet
Default Truck Stumble.
Im having problem with my truck right after i start it up and take off it will stumble and stall until it is good and warm and then it runs just fine. what could be causing this problem ?
Old Jan 10, 2008 | 02:22 PM
Mudbone25's Avatar
Mudbone25
Default RE: Truck Stumble.
ive heard vaccum leaks can cause hesatation at startup. but im not sure where.
Old Jan 10, 2008 | 03:06 PM
chet's Avatar
chet
well that would make perfect sence since i installed a vaccum gauge and spliced into my PVC hose. But all the lines were tight so i dont know where or how it is leaking. could anyone give me some pointers on what to look for ?
Old Jan 10, 2008 | 03:14 PM
Silver_Dodge's Avatar
Silver_Dodge
Can you post up some pics of your vacuum gauge and install. I'm curious to see it.
Old Jan 10, 2008 | 03:19 PM
chet's Avatar
chet
ohh so now silver dodge is calling out my install job ya let me find a camera and ill get some pics up within the next 30 min before i go to work.
Old Jan 10, 2008 | 03:42 PM
chet's Avatar
chet
Old Jan 12, 2008 | 10:14 AM
Silver_Dodge
THe pictures are hard to see because they are so small. Got any bigger ones? No, i'm not calling out your install job, just curious to see how a vacuum guage gets installed on our Rams.
Old Jan 12, 2008 | 01:40 PM
chet's Avatar
chet
ill try to get some biggeer ones, all i had on me was my phone.
Old Jan 12, 2008 | 02:53 PM
ozyran's Avatar
ozyran
My truck was having a problem similar to that, and it wound up being the intake plenum plate gasket. If you take the air cleaner off and look inside the throttle body, you'll be able to see the plenum plate. If there's no oil in there, great! If you see oil there, then the vacuum leak has been located.
Old Jan 12, 2008 | 03:00 PM
chet's Avatar
chet
my PCV had some oil covering the bottom of it, would that hint to something, but it has to be a leak cause it just has started since i hooked up my vaccum gauge
