Oil Leak Help
Old Jan 15, 2008 | 12:04 PM
RamJet's Avatar
RamJet
Default Oil Leak Help
My son has a 1998 Ram 1500 with the 5.9L engine. It's bleeding oil like a stuck pig out of the top of the engine, at the back. We replaced the oil pressure sending unit that did not fix the problem. I'm thinking rear intake manifiold valley seal. Is there anything else it could be???
Old Jan 15, 2008 | 12:09 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Oil Leak Help
I assume you checked the obvious stuff like the valve covers?
Old Jan 15, 2008 | 12:18 PM
overs ram's Avatar
overs ram
sorry, delete this
Old Jan 15, 2008 | 12:56 PM
RamJet's Avatar
RamJet
yes I sure have. Thanks for the reply. Does the distributor housing go into an oil gallery?
Old Jan 15, 2008 | 01:23 PM
padodgeram's Avatar
padodgeram
could be your sending unit didnt seat in right or not fully tighten , could be the back of the plenium gasket. get some brake cleaner and clean it up back there , then get a mirrior and start looking.
Old Jan 16, 2008 | 07:04 AM
RamJet's Avatar
RamJet
We tore it down last night. The rear manifold valley seal was definately the cause. You could see on the bottom of the intake where it had not sealed for most of the distance across. Plenum gasket was in bad shape as well.
Old Jan 16, 2008 | 12:26 PM
turkeyhunter1962's Avatar
turkeyhunter1962
When I had the same problem I didn't lose oil, I lost anti-freeze. I actually thought my heater core had let loose. At least now you can fix the plenum gasket without adding much additional work.
Old Jan 21, 2008 | 09:28 AM
RamJet's Avatar
RamJet
Truck is back together now and all is dry! Had to tow the boy home from work last night. Acted like it ran out of gas. Fuel delivery problem. Fuel pump is bad, line is frozen, bad relay, etc.... Pump doesn't run when key is turned on. More fun today!
Old Jan 22, 2008 | 12:10 PM
RamJet's Avatar
RamJet
Fuel Pump was bad.
Old Jan 22, 2008 | 12:34 PM
IndyRamMan's Avatar
IndyRamMan
I would have sworn you put the sending unit in the wrong hole. I did the same thing back in the summer.
