Upgrading my truck
Old 02-16-2008, 09:36 PM
RUgbykid69's Avatar
RUgbykid69
RUgbykid69 is offline
Default RE: Upgrading my truck
alright im probably gonna be doing the 14x3 air cleaner this weekend..i was wonderign if the bolt for the air cleaner is with the cleaner in the box or do you have to buy that seperate?? also besides cleaning the throttle body is there anything else imight as welldo while working on that?? also just out of curiosity what sites or stores have performance chips??
also thx for all the help..i really appreciate it
  #32
Old 02-16-2008, 09:47 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
USE THIS AIR CLEANER!!!! IT IS ONLY 18 DOLLARS!! YOu don't need to do any custom rod bending. It net me 2 more MPG from the stock box WITH a k&N and better response. Do not buy the K&N filter and put it into the POS stock airbox.
http://store.summitracing.com/partde...p;autoview=sku
YOu will need to cut the bolt they give you because your throttle body will not go deep enough to secure it. Once you buy it you will know what i am talking about.
  #33
Old 02-17-2008, 10:26 AM
RUgbykid69's Avatar
RUgbykid69
there is just one last question before i start...what about the map sensor??
  #34
Old 02-17-2008, 11:07 AM
IndyRamMan's Avatar
IndyRamMan
IndyRamMan is offline
ORIGINAL: Cereal Killer
ORIGINAL: nolazach
Alot of people who get them, do swear on them. I bought on just because it might make the CAI look cooler, then I decided not to go with the CAI. I don't know if I will even put the spacer on, I think I wasnt the mopar filter, or an oval one; haven't seen that yet.
Go pop your hood and look at your intake manifold and Look where your throttle body is located on it, and explain to me how you think a throttle body spacer is going to help that system? Why do you think it would it help? Because it costs money? Alot of the people who get them and swear on them probably don't drive dodge rams, and you should look at the intake manifold of the car that they drive, and you'll understand why it works on thiers and not on yours. They're vehicles are throttle body injection, our trucks are port injectionIt's about as funny as the idea of a "Cold air intake" cooling the air inside your CAST ALUMINUM intake. That stores and enormous amount of air that heats up the second it comes in...
Now on a plastic intake manifold a cold air intake makes alot of sense...
YAY!!!
FYI either way the colder the air into the intake manifold the lower the temps when the air gets to the heads. Ex, if you have a dry shot of nitrous before the throttle body, its going to cool temps to about 20-50*F depending on app. If normally your intake temp is about 150*F after going through the intake manifold it doesnt mean that the air fed by nitrous is going to rise to 150*F. Temps in the intake manifold are not a constant, though they are a constant increase if the manifold has not been altered/cooled. (constant meaning the temp will always be the same, constant increase meaning it will always increase the air temp by X ammount) So yes you are right, it wont reduce the ammount that the intake manifold increases the air temp by, but it will reduce the final temp....that is IF the cold air intake is actually doing its job rather than selling you some **** and bull story.
ORIGINAL: CPTAFW163
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EDL%2D1002&am p;N=700+4294756384+400065+115&autoview=sku
dude, is that 18 after shipping an handling? thats 6 bucks cheeper than pepboys.
nevermind...i clicked it lol
  #35
Old 02-17-2008, 12:52 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
ORIGINAL: IndyRamMan
YAY!!!
You're comparing apples to oranges here man. A dry shot of nitrous is a totally different animal than a cold air intake, that's basically an open element version of the stock air box. A shot of nitrous would actually cool the air significantly enough to make an improvement. Air collected through a CAI 18 inches away from the motor and a foot away from the exhaust manifold, that then has to travel through a metal tube that keeps getting closer to motor until it gets into the alumium manifold is going to be what? maybe 1 degree cooler if at all? All be it, it is less restrictive than the stock air box is, I seriously doubt the air is going to be any cooler through it than the air coming through the stock box.
  #36
Old 02-17-2008, 01:15 PM
IndyRamMan's Avatar
IndyRamMan
YAY!!!
I think were arguing the same point here. I am 100% in agreement about the fake cai nonsense. Im talking about things that actually work, things that pull air from outside the engine bay. Temps inside the engine bay can get up over 150*...never will you find a day on earth thats hotter than 150*. So no matter what youll be getting colder temperatures if you are pulling air from outside of the engine bay (through a sealed and properly protected, from heat, system)
  #37
Old 02-17-2008, 01:21 PM
Cereal Killer
YAY!!!
Agreed
Quick Reply: Upgrading my truck
