strange acting thermostat
Old 01-30-2008, 01:03 AM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
Default RE: strange acting thermostat
double check that rad cap is the same "lbs rating" as the stocker, otherwise sounds like you got things under control.
  #22
Old 01-30-2008, 07:01 PM
danm9's Avatar
danm9
danm9 is offline
none of this really explains why the gauge is spiking so high. i think i'll re-replace the sensor. do yo uguys know if there is only one temp sensor i should replace or is there another somewhere? thanks again for the help.
  #23
Old 01-31-2008, 12:59 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
there is only one coolant temp sensor, on the front of the manifold, behind the alternator. the is an IAT intake air temp sensor, but its an engine tuning contol, also on top, front, passenger side of intake.
what did your top hose feel like when temp gauge hit about 190 ? hot or cold ?
  #24
Old 01-31-2008, 08:23 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
ORIGINAL: dhvaughan
installed correctly.
Whoa, whoa, *WHOA*!!! This isn't installed pellet side DOWN?!?!?!?! If that's the case, then mine's installed upside down, and has been causing me NOTHING BUT GRIEF for over a year!!!!! [:@][:@][:@]
  #25
Old 01-31-2008, 11:30 PM
dhvaughan's Avatar
dhvaughan
spring and sensor goes down. dome side up.
  #26
Old 02-01-2008, 09:11 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
I am going to double-check it this weekend. Boy, will I feel stupid if it's in wrong. [sm=bomb.gif]
  #27
Old 02-23-2008, 07:59 PM
danm9's Avatar
danm9
danm9 is offline
ORIGINAL: dhvaughan
so i checked those upper hose finally and it doesn't seem very hot until the 230-240 range. before that i think it's just engine warmth.
my gauge is still spiking very high before settling down tothe 210 range. i replaced the temp. sensor again and i also replaced the other sensor there while i was atit. both went down into coolant. i am at my wits end with this thing.
  #28
Old 02-24-2008, 10:36 AM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Sounds like a bum tstat.
Buy a new one and drop it in a pan of boiling water. Water will boil at 212* and won't get any hotter than that. if the Tstat pops open then it will open at at least 212*. Remove the heat source and put in a temp guage like a meat thermometer and watch the temp as the tstat closes, that's the temp that it opens and closes at in the engine. the tstat should close at roughly the temp stamped onto the tstat. If it doesn't get a new, more accurate tstat.
  #29
Old 02-24-2008, 02:43 PM
danm9's Avatar
danm9
danm9 is offline
ORIGINAL: aim4squirrels
i thought it was a bad tstat too so i replaced it again and got the same results. with two tstat doing it i figured i could rule it out. do you think this could be a wiring issue from the sending unit?
  #30
Old 02-24-2008, 02:48 PM
danm9's Avatar
danm9
danm9 is offline
ORIGINAL: VWandDodge
let us know man.
Quick Reply: strange acting thermostat
