stupid move on my part!
Old Feb 2, 2008 | 01:23 PM
lastrights's Avatar
lastrights
Default stupid move on my part!
yesterday i was going up a snowy icy driveway. i usally have it in 4 high, i had a lil trouble, so i though hey i never use 4 low, man what a diffrence ,got out no problem.nowe the dumbass part. i got onto the road, wet pavment. i was going bout 25 took it out of 4 low into 2 wheel, and had the worse grinding noise ,clunks and it was loud[:@], i got home ok , i hope i didnt hurt anything, i havent drove it since then, so hopefully when i go to use 4wd evreything will be good.
Old Feb 2, 2008 | 02:08 PM
rabbler's Avatar
rabbler
Default RE: stupid move on my part!
You should be OK but next time wait 'till your stopped or just slightly moving to engage or disengage 4low
Old Feb 2, 2008 | 02:38 PM
zique's Avatar
zique
Yep, make sure you are stopped when shifting to or from 4low. 4 high is usable at lower speeds, but 4-low is not.
Old Feb 2, 2008 | 03:36 PM
Cereal Killer's Avatar
Cereal Killer
Make sure your tansmission is in neutral when shifting into or out of 4lo. If the truck is running try to have it rolling about 1mph. If the truck is stopped turn it off completley with the tranny in neutral, then shift in or out of 4lo. Then start the truck back up. That's the best way to avoid the grinding.
Old Feb 3, 2008 | 02:31 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
I agree you should be okay. I usally just stop andleave it in nuetral to shift out of 4lo. Then I dont hear grinding.
Old Feb 4, 2008 | 01:07 AM
cdusthockey's Avatar
cdusthockey
you just got to push and pull that lever hard and fast. when you move it slow youll get the grinding. youll get some grinding but at least you know its in.
Old Feb 4, 2008 | 01:40 AM
dishdude2k's Avatar
dishdude2k
ORIGINAL: cdusthockey
do WHAT? ? hard and fast is good in some cases.. but not the transfer case.. be lucky u havent bent or broke anything.. to take it in or out of 4wd .. do EXACTLY as the others have said.. put the vehicle in NEUTRAL .. then shift it... not hard.. not fast.. steady... mine used to grind when i got it.. turned out all i needed to do was adjust the lever from under the truck.. a 9/16 wrench and 5 min later.. it was flawless.. and it has never grinded since.. just take it easy.. these trucks take a beating.. thats for sure.. but ya gotta take care of them as well.. why break something by being neglegent.. but hey.. who am i to tell you what to do with your 1500 bucks (on the cheap side) .. sure the transmission shop will like you
Old Feb 4, 2008 | 02:04 AM
cdusthockey
you really think i am telling him to be going 60 down the freeway and slam it in 4wd??? i hope not! i am just saying that when your stopped and in Neutral you should give it a nice pull to get it in and out of 4wd. sometimes it will get stuck between 2wd and 4wd. thats when pulling it a bit will get it in and out of 4wd.
