quarter mile time
Old Feb 2, 2008 | 08:08 PM
00RAM360's Avatar
00RAM360
Default quarter mile time
I was just wondering what you guys think would shave the most off my quarter mile timebetweena superchips tuner, or a detroit truetrac. I think both are similar in price. My best time so far is a 17.05 at about 80mph spinning my rear tire on the launch, because of the open differential. I tried it in 4WD, but it sucked the power out at the top end for like a 17.4 second pass. Thanks.
Old Feb 2, 2008 | 08:33 PM
zddp8868's Avatar
zddp8868
Default RE: quarter mile time
ORIGINAL: 00RAM360
what was your 60 foot time? a posi type unit like the "truetrac" won't really help severe traction issues. it will alleviate them a bit but your best bet for traction would be a set of STICKY TIRES or TIRE! adding power will help you on the top end but you wont see a major decrease in ET unless you learn to launch properly, and you control tire spin. if it were my truck, id first make sure i removed unnecessary items from the truck, then id start with getting traction before i added any power. why areyou only limiting yourself to those two products?
Old Feb 2, 2008 | 08:44 PM
00RAM360's Avatar
00RAM360
best 60foot was like a 2.80. I just figured superchips is a fairly cheap way to add power and change things such as rev limiter, and the truetrac would get both tires power to eliminate the spinning. Both products are about 400-450 dollars.
Old Feb 2, 2008 | 08:54 PM
zddp8868's Avatar
zddp8868
ORIGINAL: 00RAM360
2.80. wow. well id forego any power adder just yet. first, id say that your launch is in need of some help. ease into the throttle. im sure you are easing into it, but ease into it MORE. a cheap way to increase traction is to throw a bag of dirt or concrete mix or anything over each rear wheel or axle. since you only have an open rear, throw a bag or two over the one wheel. it does add weight, but the traction increase will show to be worth it. id check into some ladder bars or traction bars for your truck as well as a set of slicks. a posi type differential is always more fun and it does increase traction, but not by huge amounts.
get it to hook, then morepower. get it to hook again, then add power again. wash, rinse, repeat.
Old Feb 2, 2008 | 09:55 PM
00RAM360's Avatar
00RAM360
Scratch that.I was lookingat the wrong side of my timeslip.Mybest 60 foot was a 2.47.I don't know if that makes a difference in what to do or not.
Old Feb 2, 2008 | 11:56 PM
zddp8868's Avatar
zddp8868
ORIGINAL: 00RAM360
2.47 is still HORRIBLE. follow my above advice.
Old Feb 3, 2008 | 09:55 AM
Houston4x4's Avatar
Houston4x4
Why are you drag racing a 4WD Dodge anyway? Go find some mud.
Old Feb 3, 2008 | 01:13 PM
Sirhilton17's Avatar
Sirhilton17
Ive tooken mine down the strip once... just for the hell of it to get a baseline...
16.35 ... I dont remember at what speed, I lost my time slip.
Ill run it again this spring.
At the time the truck has basically all the mods it has now.. hypertech, dual exhasut... thats it when I raced it and I have a 5.2 too.
Old Feb 3, 2008 | 01:17 PM
Cereal Killer's Avatar
Cereal Killer
I wouldn't waste the money on a true-trac when a detroit locker doesn't cost that much more, and it will work alot better.
