Where to get M1
Old Feb 3, 2008 | 08:59 PM
hometheaterman's Avatar
hometheaterman
Default Where to get M1
Where can I find the M1? I have a little oil in my intake but it's not a ton. I thought maybe it was just normal but after seeing the post with the pan off with the oil in it mine might be blown as it's like that just about 1/4 that amount maybe half that. I had to take the TB off to see it at all and its not much. I also pulled the pcv and breather hoses off and held them then let go and they blew out. I was told this is what they were supposed to do.
Anyway if I do have a blown pleneum I would like to get a M1 intake. Where can I Find them? Any links? I saw them on Summit but they all said for carbed engines. Do I need anything else when I get it or is this all I need? Thanks.
Old Feb 3, 2008 | 09:08 PM
pcfixerpro's Avatar
pcfixerpro
Default RE: Where to get M1
I think for a stock setup, you do not want the M1 intake. Aparently it is better for higher rpm's and power, but in our case with stock trucks, the stock kegger does decent enough. Silver_Dodge just did his plenum and cut his runners down. Might wanna take a look over there if your really looking to put some time into it.
padodgeram's Avatar
padodgeram
http://www.mopartsracing.com/parts/ram.html scroll down , you will see it... are you sure this is what you want ?? stock pcm , stock heads ??? plus the cost of the m1 ?? some say you mite lose some low end others said no.... im still up in the air about it...
Old Feb 3, 2008 | 09:11 PM
pcfixerpro's Avatar
pcfixerpro
you can check over at summit racing also. they have a few but I never looked into it enough to provide a direct link for the correct 1.
Old Feb 3, 2008 | 09:12 PM
hometheaterman
I'm not sure if thats what I want or not. I just want it done right and figure a little extra power can't hurt. I just dropped 6k+ into this truck and figure I want it all fixxed. I will be having a shop doing it as I've read a few DIY threads and it seems way harder than my skill level. If I get the APS kit how much should I be looking at for a shop to install it? I really don't want to drop another grand into this thing but I don't want a problem with it either.
Old Feb 3, 2008 | 09:14 PM
hometheaterman
Maybe I just want the APS kit.
Old Feb 3, 2008 | 09:17 PM
padodgeram's Avatar
padodgeram
matter of fact its a MPI , same as an M1 ??
Old Feb 3, 2008 | 11:01 PM
hometheaterman
Is this the same one I need? http://store.summitracing.com/partde...p;autoview=sku
If I get that what else do I need?
Old Feb 4, 2008 | 12:13 AM
beaner's Avatar
beaner
The M1 intake you want is part # p5007852 without egr or p5007398ab with egr. you will also need the installation kit part# p5007638. You can find these on the MOPAR PERFORMANCE website in the jeep/truck section. Edelbrock also has one to that is a direct bolt on. Hope this helps.
Old Feb 4, 2008 | 12:17 AM
Silver_Dodge's Avatar
Silver_Dodge
Get the 4 barrel M1. It's cheaper then the 2 barrel and said to perform better too, and you can just use the adapter plate to convert it from carb to throttlebody.
