Does anyone have a Scanguage II?
Old 06-07-2010 | 10:00 PM
RamSport97's Avatar
RamSport97
Originally Posted by rmay635703
I own one and love it, my 01 2wd 1500 crewcab 5.2 is up to a little north of 19.3mpg 70% highway 30% town. (put stock 225 tires on the front and FE went up) See if I can keep it up, once the temps drop later this year my FE will be back in the gutter though
Also I would love to know which X-guage settings will grab the transmission temperatures . From what I remember you need to know what parameters (from the factory in hex) which will grab the trans temperature from the ecu, it varies by year, engine and model.
Sounds great, but read the post directly above yours.
  #22
Old 06-08-2010 | 06:55 PM
rmay635703's Avatar
rmay635703
Yes, but many X-guages are floating around that are not provided by the company itself, if you can find someone who understands the target Dodge ECU you just need to know where to poke to get the transmission probe information (if the truck even has one)
I would love to reprogram my ECU to lean out a bit once I am up to highway speeds like the european trucks do, gains about 20% on mileage. The ideal (mpg wise) ratio is 16.7:1, it only works for steady state and increases Nox 20%. If you need to accelerate your ratio needs to drop between 12 & 14.7:1
Cheers
Ryan
  #23
Old 06-08-2010 | 07:35 PM
RamSport97's Avatar
RamSport97
Cheers
Ryan
Interesting, if you can find the trans temp Xgauge and other reprogramming codes, be sure to post here, does the Horsepower gauge work? Did the unit help you get any better mileage by monitoring your fuel consumption?
As for the trans temp, I am going with Silver Dodge's setup, should be here tomorrow along with the ScanGauge2.
http://carphotos.cardomain.com/ride_...0070_large.jpg
  #24
Old 09-17-2013 | 09:38 PM
skrzastek's Avatar
skrzastek
Bringing this back from the dead, has anyone figured out the commands to get the trans temperature?
  #25
Old 09-18-2013 | 12:32 PM
I don't think it is supported on the Dodge.....
  #26
Old 09-18-2013 | 01:00 PM
ChillyPhil's Avatar
ChillyPhil
Would this work with the SCT tuner? I figured it would, but don't know if it would interfere with anything.
  #27
Old 09-18-2013 | 01:01 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Yep. It just reads stuff from the various sensors on the truck.
  #28
Scangauge is just reading the data stream from the pcm, it doesn't care what tune is on it.
  #29
Old 09-19-2013 | 09:37 AM
ChillyPhil's Avatar
ChillyPhil
I better start making a to-buy list.. Seems like a good investment.
  #30
Old 09-24-2013 | 12:57 PM
skrzastek's Avatar
skrzastek
Since there is a trans overheat light, shouldn't the scangauge be able to tap into that signal? Or is that light basically a dummy light
