Tow truck is on it's way
Old Feb 4, 2008 | 07:08 PM
Obiejuankinobie's Avatar
Obiejuankinobie
Default Tow truck is on it's way
My big Red Dog did not start this morning. No warning crank cranks like a champ but does not start. I had a mechanic come over while I was at work. He said it has spark but he cannot work on it in the drive way so I have my AAA come out and tow it to his place.
If it has spark I bet its the gasoline pump. Would a pump go just like that????
Old Feb 4, 2008 | 07:14 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: Tow truck is on it's way
Yeah that's how my pump went. Drove it home from work just fine (30 miles no less) turned it off. Came back out a few hours later and it wouldn't start. Didn't start to wine or give any warning before hand. The pumps aren't too expensive. I think mine was $500ish. Kind of a pain to change in you driveway too because you have to drop the tank.
Old Feb 4, 2008 | 07:34 PM
Ram2K1's Avatar
Ram2K1
ORIGINAL: Cereal Killer
Not sure where you live, but around here, $500ish is kind of on the expensive end.
Old Feb 4, 2008 | 07:39 PM
Cereal Killer
Well I mean it's not going to set you back the way engine, axel, or transmission problems would set you back. It's closer to the low end of expense as far as automobile parts are concerned.
Old Feb 4, 2008 | 07:50 PM
motorbrreath's Avatar
motorbrreath
have fun replacin that bitch... i couldnt get the front strap off my tank and it took me forever to work the pump in the tank with one strap off. and now the gauge doesnt work.
Old Feb 4, 2008 | 07:53 PM
Jr. Mechanic's Avatar
Jr. Mechanic
I had to replace both fuel tank straps on my uncle's 96 for him, and man that was a PITA. One of them rusted all the way through, while the other on was on the brink of rusting through. It took me 45 minutes per nut to get off, I just had to keep working the nut back and forth to chase the threads while spraying it with WD40.
1996Ram318's Avatar
1996Ram318
I didn`t have any problem changing mine. The straps will come off a little easier if you put a little pressure on the tank with a jack.
Old Feb 4, 2008 | 07:56 PM
pcfixerpro's Avatar
pcfixerpro
heck with all that! I hope mine doesn't go, but couldn'tyou just unbolt the bed and pull it off? Grab a few people and just lift it off?
Old Feb 4, 2008 | 08:07 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Hey the bed came off no problem. My tank was on there and I didnt want to monkey with straps. Two 2x4's and 4 guys 2hours and she was done. 200 bucks.. fora rebuilt one from ebay. been in there three years no problem.
Old Feb 4, 2008 | 08:12 PM
TheForce55555's Avatar
TheForce55555
Fuel pumps are 500$$, holy crap, are you serious Cereal???????
