HOW MUCH OIL IS TOO MUCH ?
Old Feb 11, 2008 | 10:31 PM
citygasdude's Avatar
citygasdude
Default HOW MUCH OIL IS TOO MUCH ?
I am running synthetic oil in my 99 Ram with at 5.9, I change it about every 5,000 and have to add about a quart before the next oil change. Does that mean that its leaking oil at the plenum or is that normal for an engine with 113,000 ?
[IMG]local://upfiles/31643/513836EF539847FC878516892DF5D4B9.jpg[/IMG]
Old Feb 11, 2008 | 11:11 PM
TheForce55555's Avatar
TheForce55555
Default RE: HOW MUCH OIL IS TOO MUCH ?
I would say that is about normal, to check your plenum look into the TB with a flashlight and see if there is oil pooling, especially in the rear..
Old Feb 11, 2008 | 11:18 PM
kowboydmac's Avatar
kowboydmac
I didn't think synthetic burned off? Darn oil. lol.
Old Feb 11, 2008 | 11:21 PM
XXL 1500's Avatar
XXL 1500
yeah 1 entire quart is way too much for a gasser.
def. sounds like plenum
Old Feb 11, 2008 | 11:23 PM
TheForce55555
Throw synthetic oil on a fire and see what it does.....
Old Feb 11, 2008 | 11:40 PM
cdusthockey's Avatar
cdusthockey
it may not burn, but it will deffinitly burn in the motor. sounds like your plenum is leaking. 16xxx miles and no plenum. Knock on wood!! but i dont burn any oil. prolly a time for a oil change since its been 4500 miles since ive changed my oil on my pickup. (Valvoline 5w30) it been too cold up here to change my oil but i better get to it.
Old Feb 11, 2008 | 11:53 PM
rabbler's Avatar
rabbler
1 quart in 5k isn't bad at all. Could be the start of a plenum leak. Ever change the PCV?
How heavy of an oil do you run? 5w30, 10w30?
Old Feb 12, 2008 | 12:43 AM
IndyRamMan's Avatar
IndyRamMan
My general rule of thumb is to fill the engine with the same capicity that your gas tank holds. if you have a 26 gal tank, 26 gal of oil...30 gal, 30 oil. Thats why dragsters run small fuel cells that have less than 10 gallons, because the more oil the more weight on the crankshaft, meaning less power. Thats how you get deep in the 6's.
Old Feb 12, 2008 | 12:48 AM
zddp8868's Avatar
zddp8868
[sm=icon_rtfm.gif]
Old Feb 12, 2008 | 09:38 AM
citygasdude
Right now Im running quaker state 10w30 syn. at the next oil change Im switching to mobil one 10w40 high mileage. I haven't change the pvc since I bought the truck with 103,000. I will change that today and check in the throttle body with a flashlight this weekend to see if I have a plenum kit in my future, LOL. Thanks for the advice
