Intake and timing chain cover gaskets leaking
Old Feb 17, 2008 | 06:29 PM
kurrz96ram's Avatar
kurrz96ram
Default Intake and timing chain cover gaskets leaking
While I'm having these two problems fixed is there anything else I should have done while the truck is apart? I am going to have a new timing chain and sprocket set done but, is there anything else? The truck just turned 100K. Thanks guys.
Old Feb 17, 2008 | 06:39 PM
dhvaughan's Avatar
dhvaughan
Default RE: Intake and timing chain cover gaskets leaking
water pump, water pump bypass hose, thermostat
Old Feb 17, 2008 | 09:32 PM
kurrz96ram's Avatar
kurrz96ram
Thanks for the info anything else, that's necessary or should be upgraded? I plan on beefing the truck up after all mechanical and body problems are solved. Thanks again.
Old Feb 17, 2008 | 10:11 PM
aim4squirrels's Avatar
aim4squirrels
get a double roller timeing chain, not a stock replacement.
Old Feb 17, 2008 | 11:13 PM
TheForce55555's Avatar
TheForce55555
Check the plenum gasket too......that would be a good time to do it if its blown
Old Feb 18, 2008 | 12:40 PM
kurrz96ram's Avatar
kurrz96ram
Alrighty should I get a plenum kit? Also where can I get one? Thanks
Old Feb 18, 2008 | 12:50 PM
RM_Indy's Avatar
RM_Indy
Go to Hughes for the plenum kit
http://www.hughesengines.com/partDet...p?partID=11698
Old Feb 18, 2008 | 01:15 PM
kurrz96ram's Avatar
kurrz96ram
Would you suggest getting the gasket and bolt set also from Hughes?
Old Feb 18, 2008 | 03:28 PM
aim4squirrels
Yes, get all of it.
Old Feb 18, 2008 | 09:18 PM
dhvaughan's Avatar
dhvaughan
i got my plate and gasket kit from Hughes.
several people have posted recently they got a plate and gasket kit from APS for less money.
http://www.apsprecision.com/billetplenum.html
but it looks like about the same cost to me, about $135-140 at either place.
