Where can I get gaskets for these valve covers??
Old Feb 18, 2008 | 11:22 PM
Silver1500's Avatar
Silver1500
Default Where can I get gaskets for these valve covers??
I bought these valve covers off ebay, they are used but they look like brand new. I got a good deal on them but I went to put them on and realized that they wont work with the stock style gaskets i had. Does anybody have an idea where I can get the gaskets??
[IMG]local://upfiles/82309/9292F5399380406AB885AE5DA9C9FDAD.jpg[/IMG]
Old Feb 18, 2008 | 11:27 PM
CPTAFW163's Avatar
CPTAFW163
Default RE: Where can I get gaskets for these valve covers??
Mopar performance? Try the dealership. They can order them for you.
BTW i am so jealous that you got them for a deal. So jealous.
Old Feb 18, 2008 | 11:33 PM
Silver1500's Avatar
Silver1500
I wasnt sure the dealership could order them, I probably should find the part number so im sure i get the right ones.. I guess i should have tried that first....
Old Feb 18, 2008 | 11:35 PM
Silver_Dodge's Avatar
Silver_Dodge
Yup, I got mine from the dealership for my valve covers. They are the hard platic gaskets that are reusable. I recommend before you install those that you buy the baffles from APS PRecisions. The stock baffles suck, you will get oil coming out the grommets. They came out with these that are much better.
http://www.apsprecision.com/oilbaffles.html
Old Feb 18, 2008 | 11:47 PM
Silver1500's Avatar
Silver1500
I was wondering how those grommets sealed up. Those baffles arent too big that they will interfere with the rockers are they? I plan on putting a cam in this summer and I was going to get aftermarket rockers (the same size 1.6) but I think the baffles in the stock covers need to be cut out or modified if you buy different rockers and get a cam?? Correct me if Im wrong, but thats what ive gathered about it. I could be completely wrong....
Old Feb 18, 2008 | 11:48 PM
CPTAFW163's Avatar
CPTAFW163
Silver,
I thought you can't use baffles for 1.7s? SOmeone said you can't do 1.7s without getting new valvecovers without baffles. Am I mistaken?
Old Feb 18, 2008 | 11:54 PM
Silver_Dodge
Silver1500, Those covers are taller then the stock covers, so you shoudn't have any problem clearing your 1.6's using those covers, even with the baffles.
CPTAFW163, the 1.7 rockers made by Crower, Mopar, and others do require you to beat the baffles on the stock valve covers to make them fit. Harland Sharp 1.7s are the exception, and they fit under stock valve covers with no problems. The Mopar Performance covers posted about above are taller then the stock covers, and will work with those other 1.7's.
Old Feb 19, 2008 | 12:00 AM
IndyRamMan's Avatar
IndyRamMan
Im using the stock valve cover gasket stylewith mine (also the la style valve covers)
Silver1500's Avatar
Silver1500
This is kind of off subject but if I get a cam I probly shouldnt get 1.7 rockers right?
Someone told me that 1.7s might give me too much lift if I get a cam, I dont know for sure tho.
Old Feb 19, 2008 | 12:03 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Silver1500
Not true in the least. You can run whatever rockers you want. The thing you need is to make sure that you pick the cam with an appropriate ammount of lift given the rocker ratio.
