Transmission Temperatures
Old Feb 27, 2008 | 04:14 PM
dusty_duster's Avatar
dusty_duster
Default Transmission Temperatures
I installed a transmission temperature gauge last week and have been closely monitoring the temps. I have the stock auxilliary cooler, which came with the towing package and is really large. The temperatures during the day have been around freezing all week. My gauge sender is installed in the "hot" line coming out of the transmission. During normal driving (not towing or hauling anything), my gauge rarely gets above 100*F or 120*F. When driving on a lot of hills, it might creep up to 130*F or so. I haven't towed anything yet.
What tranny temps are you seeing during driving and towing?
Old Feb 27, 2008 | 04:33 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Transmission Temperatures
I see around 150 or less when ambient temps are down around freezing or below. I see around 165-180 in the summer time unloaded, and around 210 when i'm towing in the hot summer.
Old Feb 27, 2008 | 04:42 PM
dusty_duster
Do you have the external tranny cooler?
Old Feb 27, 2008 | 04:49 PM
Silver_Dodge
Yes, rated at 32,000 GVW (way bigger then the stock cooler). Also have an oversized pan. I'm taking my reading from the front servo port. I also take a reading from the pan, but it is much lower temps.
Old Feb 27, 2008 | 09:24 PM
Truck Ram ROD's Avatar
Truck Ram ROD
would you guys recomend a tranny cooler i have a 1994 1500 V6 3.9L i do a fair bit of towing and have never thought about a cooler i had total weigt once (truck trailer load) at 12000lbs and i don't go faster than 60kms and i turn the O/D off i have thought about putting a temp gauge in for my tranny but never looked in to it what do you guys think??? thanks for any suggestions
Old Feb 27, 2008 | 09:36 PM
hometheaterman's Avatar
hometheaterman
I'd get a cooler on there for sure.
Old Feb 28, 2008 | 08:32 AM
dusty_duster
ORIGINAL: Silver_Dodge
Hmmm. When it actually stops snowing, I'm going to have to check the grounds on my sensor.
Old Feb 28, 2008 | 08:55 AM
BRETTM's Avatar
BRETTM
i have did my temp gauge install yet ( too cold ) but i have the factory cooler and a 2nd cooler as well, you can never have enough.....
Old Feb 28, 2008 | 09:05 AM
Silver_Dodge
I think a temp gauge is almost more important then a cooler. What good is a cooler if you don't even know what your temps are. You can still overheat with a cooler.
Old Feb 28, 2008 | 11:03 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Definitely get a gauge on your tranny. I pull a 9000 lb fifth wheel with my 1500 and would not even consider pulling without my gauge.
