trans swap 46 re to 46 rh?
Subscribe
Mar 15, 2008 | 08:11 PM
i have a 46 re in a 97 ram 1500 bad would like help with facts about changing to a 46 rh
Reply 0
Mar 15, 2008 | 08:41 PM
RE: trans swap 46 re to 46 rh?
Just curious as to why you'd want to change it?
Reply 0
Mar 18, 2008 | 09:13 PM
already have
Reply 0
Mar 19, 2008 | 07:33 PM
any help please
Reply 0
Mar 19, 2008 | 07:36 PM
What exacty do you want to know?
Reply 0
Mar 19, 2008 | 07:44 PM
i want to know what is the difference from the 46re to the 46rh?
Reply 0
Mar 19, 2008 | 07:51 PM
will it work with out a lot of work
Reply 0
Mar 19, 2008 | 08:05 PM
The RH has a mechanical governor vs the RE's electronic governor.
Because of the RH mechanical governor it has a longer overdrive and it makes the over all trans longer. Your transfer case should fit. You will have to shorten the rear drive shaft and lengthen the front.
The valve body is different and I don't think it will plug in to your existing wire harness.
I think you will also have fault codes in the PCM when your done that won't go away due to the RH trans missing electronic components.
I wouldn't do it.
Reply 0
Subscribe
