intake manifold
intake manifold
so i have a crack in my intake manifold, and im looking to get a new one soon as the truck has been running funny the past few days
i have 38in tall tires and when i bought the truck i was told he put in a bigger cam, and long tube headers.
my question is what would be the best replacement? i would like something stronger so i wont have this problem again, and if i need a special on for the cam, just thought to ask before buy
Thanks
Thanks
RE: intake manifold
My question is "How did you end up with a cracked intake manifold"? Those things don't break unless somebody physically beats on it or tightens some bolts too much or in the wrong torque pattern.
It looks to me like you're truck is set up for off-roading. I agree with Indy about finding out your cam specsbefore moving forward,but basically if you want to keep low end torque stay with the factory barrel style manifold. If you're looking for more upper end RPM, then the M1 intake would be your option. There is a lot of good information on this site regarding the M1 and on modding a barrel intake so do a search and see what you find.
Some of the off-roaders need to chime in with their recommendation as their experience with trucks similar to yours will be very helpful.
if you decide to go with another stock barrel intake do a search on www.car-parts.com. You should have no issues locating one for your truck.
RE: intake manifold
i know there hard to crack but my friend bought his truck with a cracked one and then crackedittwice in one year, he kept putting the stock one back on and he had the dealership do the 2nd one that cracked, so i didnt know if there was something about modding your truck is to much for that part, im almost 99% sure i can feel the air there but cant see the crack, by Friday im gona pull the motor apart and make sure its not on the headers, but there new long tube headers that arnt even 2 years old so idont thinkits them,
thanks for the help so far
RE: intake manifold
Where are these things cracking?
Here's a thought. Did the guy that had your truck mill the heads and/or your block in an attempt to increase compression? If so, he may have milled them too far as that would cause the intake manifold to not fit correctly. This could be the cause of your issue.
RE: intake manifold
ORIGINAL: turkeyhunter1962
Here's a thought. Did the guy that had your truck mill the heads and your block in an attempt to increase compression? If so, he may have milled them too far as that would cause the intake manifold to not fit correctly. This could be the cause of your issue.
Somethings been milled, or warped, or something...
I've never even heard of one of these intakes cracking.
Trending Topics
RE: intake manifold
ORIGINAL: Mike Roma
This is a different truck?
Two different trucks with cracked intakes??
ORIGINAL: Baseboy391
i know there hard to crack but my friend bought his truck with a cracked one and then crackedittwice in one year...
RE: intake manifold
Here's another option for an intake manifold. It might even have better low-end response compared to the M1. Anybody try this one yet?
http://www.hughesengines.com/partDet...p?partID=12869
