wont start afer rain
Old Mar 18, 2008 | 11:29 AM
miked5468's Avatar
miked5468
Default wont start afer rain
I have a 97 1500 4x4 with the 4.7 v8.... when cold after a rain it will not start until I crank on it forever... It is fine if I start up while still warm, or if there is no rain. Snow, ice, extream cold weather all fine. If it rains and sits overnight then it is hard to start..
Thanks for any help mike
Old Mar 18, 2008 | 11:34 AM
dodgeman22's Avatar
dodgeman22
Default RE: wont start afer rain
cracked distributor cap, same thing happened to me
Unreal2k3's Avatar
Unreal2k3
Pretty sure the Ram didn't have the 4.7 back in 97...you mean the 5.2?
Old Mar 18, 2008 | 11:51 AM
miked5468's Avatar
miked5468
sorry you are correct the 5.2 I'll check the distributor cap...thanks
any other suggestions?
mike
Old Mar 18, 2008 | 11:56 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Mike,
The crankshaft position sensor is located at the rear of the engine and just to the left of the distributor when looking at it from the front. Pull the electrical connection apart for the sensor and apply some di-electric grease then re-connect it. Do the same for the camshaft position sensor connection that comes out of the disctibutor. Water in either of these connections wil lcause your truck problems with starting.
If your hood seal leaks, water runs down your windshield and will drain right onto these two connections, in addition to your distributor. I had the same problem after snowstorms until I did this to the crankshaft position sensor. No problems since.
Old Mar 18, 2008 | 12:16 PM
miked5468's Avatar
miked5468
thanks will check both...gotta run to work, but will check back after work and try the idea listed..
thanks for the help and quick responses..
mike
Old Apr 2, 2008 | 06:00 PM
miked5468's Avatar
miked5468
still have a problem, I replaced the distributor with a new one. When I go to start the truck again it still cranks but will not fire. After cranking when I release the key the truck will chug, but not fire. I rented an auto scanner from autozone and it shows no codes. I will be greatful for any help
Mike
Old Apr 2, 2008 | 06:26 PM
mstephen89's Avatar
mstephen89
could be a bad CPS, check to see if you are getting fire, by pulling the plugs, if its fouled then at least you know that it is not fuel. Cause it could be fuel pump or any one of many sensors
Old Apr 2, 2008 | 06:30 PM
miked5468's Avatar
miked5468
what about the coil? the black box? also what is a cps? it has spark and there is a trace amount of gas on the plug....all plugs are new also
mike
