peddle to the metal;is this right
Old Mar 25, 2008 | 04:54 PM
pipeking's Avatar
pipeking
Default peddle to the metal;is this right
from a dead stop,i floor it, rpms go to about 3000 truck takes off,rpms rise alittle then back to about 3000,then starts to climb.now this all happens very fast.its like it gets put under a good load at that point,i could hear it.
Old Mar 25, 2008 | 04:57 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: peddle to the metal;is this right
My truck used to do that too for as long as I owned it, but at a lower rpm, like just off idle. I believe it was the PCM torque management. It went away completly on my truck when I got my B&G PCM with TM removed.
At 3000 rpm though, I think you might have a different issue. When was the last tune-up?
Old Mar 25, 2008 | 05:05 PM
padodgeram's Avatar
padodgeram
want a real thrill , floor it while in N and drop it in gear...
Old Mar 25, 2008 | 06:00 PM
TheForce55555's Avatar
TheForce55555
Old Mar 26, 2008 | 07:35 AM
pipeking's Avatar
pipeking
well i just did plenum,wires, plugs,oil,rad flush,but like an *** didnt do cap roter,and didnt reset pcm after either so how do i do that
Old Mar 26, 2008 | 07:36 AM
pipeking's Avatar
pipeking
everyone has a diff answer, and i dont know if it really reset, yano
Old Mar 26, 2008 | 11:41 AM
jasonw's Avatar
jasonw
Site Moderator
Disconnect the negative battery terminal for a minute (some say 30 seconds, I like to make sure). Then reconnect. That resets the computer.
It'll take approximately 40 miles-ish before the computer relearns its stuff.
Old Mar 26, 2008 | 09:28 PM
pipeking's Avatar
pipeking
can any one second this just for kicks and giggles.that is what i thought jason,but i also thought you had to turn key on after you pull neg.
Old Mar 26, 2008 | 10:26 PM
Silver_Dodge
Yes, you should disconnect the battery, then turn the ignition key to start for about 25-30 seconds. This drains the memory module in the PCM, and all remaining electrical current is discharged. Then reconnect.
Old Mar 27, 2008 | 03:59 PM
pipeking's Avatar
pipeking
alright, silver to the rescue,that is the one ive herd the most so ill go for it.i have gotten an emisions notice in the mail should i reset the pcmbefore or after?
