Oiled air intake filters
Old Apr 2, 2008 | 08:51 AM
phlash_riot's Avatar
phlash_riot
Default Oiled air intake filters
Is there anyone that knows or has had any issues with using oiled filters like K&N. I had a 99 trans am and the LS1 engine that GM uses doesn't really like the oiled ones as the oil gets sucked in and collects on the MAF sensor.
I don't expect to have any issues with the Ram and the TB but figured i would throw the question out there
Old Apr 2, 2008 | 09:24 AM
Aubrey's Avatar
Aubrey
Default RE: Oiled air intake filters
I have not but, I have a 95.
Old Apr 2, 2008 | 11:34 AM
CSCustomCars's Avatar
CSCustomCars
Our Rams do not have MAF's Sensors. At least not in 94-97's. I know about the problems with K&N and GM's MAF's. I'm a GM Fan as well.
You shouldn't have any problems with a K&N filter, but if you concered about it, I'd say go with an S&B Power Stack filter. They actually flow better than K&N and they don't use the oil.
http://www.sbfilters.com/index.php
EDIT: I'm sorry they do use oil, but they are okay for GM's. The oil isn't the same as K&N's and doesn't plug anything up.
Old Apr 2, 2008 | 11:43 AM
1BigRamaniac's Avatar
1BigRamaniac
I have a drop in K&N and have recharged it twice now. The directions are very simple. When you first get it you can see and feel how oily it is (not much). You clean it by spraying the clean side, then flip it over to the dirty side an spray it down real well. You wait for 10-20 minutes and rinse it out in the sink, naturally in reverse of the air flow. Wait until it dries, at least over night. It has to air dry. I shake the excess water off mine. I do it on Friday and re-oil it on Sunday.
To reoil I hold it 3 inches from the pleat, holding the filter verticle. Once down each few pleats, both sides, the quickly twice from about 6 inches away. Then I let it sit for about 10 minutes. The color goes from maroon to orange (never like when you got it). It is good for 12,000 miles (less if you are in dutsy conditions).
Remember, on all oil filters, including your old time lawnmowers, more oil does not equal better.
The re-charge kit will probably be good for 4-5 cycles. Cost is $10
Old Apr 2, 2008 | 11:47 AM
1BigRamaniac
To answer your other question: No issues. No extra mpg, a little extra kick when you get on it. I got it long before I came on this site, otherwise I would probably get a round as the filter is 42+10 for the charger. That is close to the black wrinkle finish Mopar round one that is so cool.
Old Apr 2, 2008 | 03:49 PM
Blaydrnnnr's Avatar
Blaydrnnnr
I have a K&N Gen II FIPK...I took it off ( and is for sale!!! )and now run the Mopar performance round cleaner....but this had nothing to do with the oil being a problem.. as I run a K&N round filter in the cleaner.. these trucks.. as you may already know.. dont have a MAF sensor.. we have a MAP sensor.. the MAF reads the air flow.. the MAP reads the manifold pressure.I'm sure your familiar with this though.. so..I dont have any problems with the oiled filter element.
Old Apr 2, 2008 | 07:58 PM
dsertdog56's Avatar
dsertdog56
I have had a few guys get oil residue (from overoiling)on the IAT, which is on the drivers side front of the intake. Cleans up easily with Intake cleaner or brakleen. Never use carb cleaner!
Old Apr 2, 2008 | 09:01 PM
xskylinedx's Avatar
xskylinedx
ORIGINAL: dsertdog56
Bingo. Thats the problem when using an oiled filter like K&N no matter what kind of vehicle your running. As long as you follow the instructions for recharging (which state not to over oil the element) then you should have no problems.
Old Apr 3, 2008 | 02:05 AM
rabbler's Avatar
rabbler
+1 You don't need to soak in it oil. More isn't better
Old Apr 21, 2008 | 07:46 AM
phlash_riot
Thanks all for the info. got a K&N yesterday.
