35x12.50 fit
Old Apr 3, 2008 | 03:21 PM
c_sport's Avatar
c_sport
Default 35x12.50 fit
I have a 99 dodge ram sportim thinking of buying a tire an wheel package will 35x12.50 with a 3in body lift fit on my truck. Or what will it take? Thanx
Old Apr 3, 2008 | 04:47 PM
mstephen89's Avatar
mstephen89
Default RE: 35x12.50 fit
Use the Search
Old Apr 3, 2008 | 04:50 PM
dishdude2k's Avatar
dishdude2k
i have a total of 6 inches lift on mine.. and if i hit a bump just right with wheels turned.. i will scrub just a hair.. and i have 35x12.5x15 's on mine.. i would probably suggest going with 33x12.5
Old Apr 3, 2008 | 05:14 PM
zique's Avatar
zique
Old Apr 3, 2008 | 06:54 PM
00dodge_ram's Avatar
00dodge_ram
nonsense i have a 2000 ram 1500 and i have a 5 inch lift with 37 14.5 16`s and they ALMOST ALMOST HIT i have to really bottom out for them to touch i mean jump off the empire state building
Old Apr 3, 2008 | 07:08 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
I agree. I have 5" of lift, and it swallows my 35/12.5/17s.
Old Apr 3, 2008 | 08:14 PM
Cereal Killer's Avatar
Cereal Killer
ORIGINAL: c_sport
Make sure the wheels you buy have adequate backspacing. If you don't go offroad 3" will CLEAR 35s. If you do go offroad 5-6 inches would be better.
Old Apr 13, 2008 | 07:02 PM
hellraiser69's Avatar
hellraiser69
I have a 2001 Dodge Ram 1500 xted cab sport.I have 35x12.5x16's on it with a 3" suspension lift.I agree with dishdude,33's would be a better choice,especially if you have the 318,the 35's tend to rob power from the 318.My tires rub on the inner backside of the fenderwell some and when turning tight and slight rollof the truck its really bad,I plan to add 3"'s of body lift to it to resolve the issue.
Old Apr 13, 2008 | 09:44 PM
hometheaterman's Avatar
hometheaterman
I have a 3" lift and my 33"s will rub when I hit a bump at full lock. The biggest thing is the wheels. The reason mine do that is it's 16x10 wheels. People like 01DodgeRam1500 have narrow stock wheels so they work. You need to get 8" wheels with the right backspacing if you want to run them and even then you might rub slightly. If you get too high of a backspacing you will rub on the control arms though. Stock wheels seem to do that somewhat.
pipeking's Avatar
pipeking
i have the mt mtz315/70/16 on a stock 99 sport ext.they rub at fuull **** i got a 3' lift coming and after that im sure it will be fine.
