Transmisson problem after oil change
Old May 22, 2008 | 11:23 AM
  #21
theviper90210's Avatar
theviper90210
Default RE: Transmisson problem after oil change
Ok so what should the dip stick show after the truck has been sitting for a few hours after it has all settled. Because mine shows in the ok margin after it has sat. I feel like when I check it when its running its hard to get a good reading on the dipstick. Right now its shift great through 1 thru 3 but when it shifts into overdrive it is kinda rough like it shifts a little hard. Is that normal for overdrive? Or do I need to adjust something with the overdrive. Thanks again guys just trying to figure these things out
Old May 23, 2008 | 08:29 AM
  #22
theviper90210
So what do you guys think?
Old May 23, 2008 | 08:50 AM
  #23
timsalas's Avatar
timsalas
Run it a little, drive around, Put it in neutral.. turn off the engine and check it.. thats hwo I do do it
Old May 23, 2008 | 02:26 PM
  #24
padodgeram's Avatar
padodgeram
wrong !!! Hot , in (N) with the truck running.. make sure you use the parking park...
If you guys do pull the trans dipstick it will say the same thing , read what it says on there ..
To much or not enough fluid your asking for trouble..
Old May 24, 2008 | 01:51 AM
  #25
timsalas's Avatar
timsalas
Well, Im a dumbtard.. added another quart lol
Old May 24, 2008 | 04:13 PM
  #26
theviper90210
so what do yall think about the overdrive?
