FOR SALE my truck
Old Jun 5, 2008 | 09:21 AM
IndyRamMan's Avatar
IndyRamMan
Default RE: FOR SALE my truck
Pulled the trans on monday to get it rebuilt. 6 new shocks comming, poly mounts, new headlights, and something else im forgetting.
Old Jun 5, 2008 | 03:29 PM
RM_Indy's Avatar
RM_Indy
Sorry to hear you have to part with the Indy
Old Jun 5, 2008 | 11:20 PM
engineblock's Avatar
engineblock
Hey indy if you are choosing the mustang over the ram, it is not a good idea i had a 90 mustang gt with cam and everything but i had to work on it almost every week cause something will break, i sold it for my dodge, i have not had any problems with it yet, think about it
Old Jun 6, 2008 | 11:53 AM
CPTAFW163's Avatar
CPTAFW163
ORIGINAL: engineblock
I agree. I had an 86 camaro with a crate 350 (trick flow heads, 280 Duration cam). First i blew my piston rings when i dorve it 45 mins, and didn't know the oil pressure sending tube touched the headers...all the oil leaked out.
THen there was me blowing my rearend when i was spinning tires for half a block and it finally hooked.
Just drive the mustang and don't do anything but intake, exhaust and roller rockers. However, if you want a camshaft. Have Ed Norton custom grind you one once you found out th heads you want.
Here is a good build for a 5.0:
AFR Heads
Ed Norton custom ground camshaft (you have to call him)
Cobra intake
Bigger injectors, but set the fuel pressure at 55PSI
Scorpion roller rockers
X pipe exhaust
Nittos DRs
Black magic electric fan (the only single fans worth a crap)
^^ that will get you into the mid 11s easy. Add spray for 10s
Old Jun 6, 2008 | 10:09 PM
IndyRamMan's Avatar
IndyRamMan
Im leaving it stock, thanks though.
Old Jun 7, 2008 | 09:52 PM
Midnight95's Avatar
Midnight95
ahhh thats sucks man, i wouldnt mind getting my hands on that to have while im building mine. What exactly is done to it? i know you have a lot of time and changes into it. I def need a refresher. Where are you located?
