Advancing timing on a 5.9L Ram
Old Jan 24, 2005 | 08:11 PM
MoparMitsuPower's Avatar
MoparMitsuPower
Default RE: Advancing timing on a 5.9L Ram
I think they did change the plenum gasket, but what you're talking about sounds about right. He said someone recommended some aftermarket shops for reflashing the ecu, but he wasn't sure if that was the only alternative. So you're saying that it CAN be reflashed by the dealer, or that they won't do that? OR, that he should take it to an aftermarket tuner?
Old Jan 25, 2005 | 02:20 AM
DWILHA's Avatar
DWILHA
you can have them reflash it but they will tell you its not gonna fix it, and they will charge you about 150.00 to do it
Old Jan 25, 2005 | 05:35 AM
carshemi's Avatar
carshemi
ORIGINAL: DWILHA
TIMING CAN BE CHANGED ON A 5.9 ITS A DISTIBUTOR, 5.9 TEND TO LABOR KNOCK IN THE HEAT ESPECIALLY WHEN USING THE CHEAP GAS TRY USING PREMIUM AND THE LABOR KNOCK WILL STOP, IT HAS BEEN PROVEN IN THE 5.9 THAT PREMIUM FUEL GIVES THE 5.9 1BOUT 10 MORE HORSES DO TO THE HIGH TIMING CURVE, YOU CAN RETARD THE TIMING ABOUT 4 DEGREES AND IT WON'T LABOR KNOCK ANYMORE , BUT IT KINDA RUNS LIKE A DOG AND GET WORSE FUEL MILAGE, AS FOR SOMEONE SAYING YOU CAN'T ADVANCE OR RETARD THE TIMING THEY NEED TO BE SLAPPED, THIS AIN'T NO CARAVAN
Thats why it runs like a dog and gets worse milage when you turn the dist. FUEL SYNC. is off! Crank shaft sensor tells distributor when to spark. The cam sensor in the dist. works with the crank sensor to determine fuel injection and the ignition spark funct.[8D]
Old Jan 26, 2005 | 12:15 AM
MoparMitsuPower
So then, what is he supposed to do? Is there ANY way to return the timing?
Old Jan 26, 2005 | 05:01 AM
carshemi's Avatar
carshemi
I have heard about the "death flash" create a problem to fix one? After market tuner like steve00 said, ask around but I belive certain tuners for certain years. Either buy one or find some one that has one,might let you use it? JMO.
Old Jan 26, 2005 | 04:11 PM
MoparMitsuPower
So, I think maybe we're on two different pages. Do you mean an aftermarket tuning shop or a piece of equipment for aftermarket tuning. I was referring to aftermarket "tuners" as in shops that do aftermarket tuning.
Thanks again y'all
Old Jan 27, 2005 | 05:43 AM
carshemi's Avatar
carshemi
Yes after market tuners like hyper-tec, super chips, and you might ask around but a mopar performance pcm might fix it too? Depends on what you are willing too spend too? Haven't used either,getting one after income tax? But I wouldn't go to that same dealer that started the DF. JMO.
Old Feb 7, 2021 | 08:53 AM
Tripp's Avatar
Tripp
Ya the cam sensor is inside the distributor.so when you turn it the computer does not register the change ....
Old Feb 7, 2021 | 09:02 AM
Moparite's Avatar
Moparite
You are aware this is a 16 year old thread right?
Old Feb 7, 2021 | 09:42 AM
16 year old thread, and wrong information as well.... Turning the distributor does not affect ignition timing at all. That is all controlled by the computer. Only way to alter timing is to change the programming.
