Stalling, Low RPM, Idle problem.
Old Jun 12, 2008 | 09:34 PM
CowboyBob's Avatar
CowboyBob
Default RE: Stalling, Low RPM, Idle problem.
Mine did the same thing. It was the IAC. $50 and 20 minutes to replace.
Old Jul 13, 2008 | 07:44 PM
dudinator101's Avatar
dudinator101
Junior Member
Hi,
Mine is doing the same thing. I was wondering if you ever solved the problem and if so, how so??? Also, I am running a K&N filter and I just read on another formum that replacing it with a paper filter, may fix the problem...hard to believe but I am going to try at least. Anyway, please let me know if you figured it out!
Thanks
Old Jul 13, 2008 | 10:36 PM
kitchenrat1's Avatar
kitchenrat1
Mine is a 95 but did the same thing. Dealer replaced the pcm for $400 and that fixed it. Unfortunately for me I also paid them $1000 in other repairs in search of the problem before the only thing left that could possibly be wrong was the pcm. Possibly check the plug wire routing. There is a tsb that is pretty specific about this.
[align=left] [/align]
