Stalling, Low RPM, Idle problem.
Old Jun 6, 2008 | 09:36 PM
NickBoudin's Avatar
NickBoudin
Default Stalling, Low RPM, Idle problem.
Hey all. I own a 94 dodge ram, and about 1 month ago she's developed an idle problem. Only when I come to a stop, does the RPM's slam down to 0, and then bounce from 0-1 and then she'll choke out and die. I've replaced plugs, wires, cap, rotar, PCV, EGR, ICV, catalytic converter, and my fuel pump. I still have problems. I brought it to my local dodge dealer, to find out it was a defective fuel pump. Today it was replaced, and instaled no charge. Though, the problem is still in play, unfortunetally. What are your thoughts on this sittuation? It's a 1994 dodge ram, 1500. 5.2 with a manual transmission. 77k miles.
My dad's a mechanic, but he deals with older vehicles. Not up to par with all the fuel injection, and electronics of the newer stuff. I've learned from him, and am learning as I'm going. Basically we're sick of guessing, and have no idea as to what the problem is.
There's no vaccum leak as far as we know, and the batterie seems to be in full working order, as well as the alternator.
Check engine light has never been on, since I've owned it, though the bulb does work!
Send your thoughts my way, because I've got none left!
Thanks in advanced,
Nick
Old Jun 6, 2008 | 10:06 PM
NickBoudin's Avatar
NickBoudin
Default RE: Stalling, Low RPM, Idle problem.
Here's some pictures!
Anyone ever see a holley mts sport edition ram?
Old Jun 7, 2008 | 11:53 AM
RM_Indy's Avatar
RM_Indy
IAC(idle air control), back side of tb probably needs replacing
TPS(throttle position sensor) drivers side of tb may also need to be replaced
Remove tb and clean it with carb clean as well.
Never seen/heard ofa Holley MTS
Old Jun 7, 2008 | 05:35 PM
CPTAFW163's Avatar
CPTAFW163
Check your breather. If its clogged your RPMs will go WAY down. Or if you blocked off the breather tube that connects to the Airbox. THat would do that. Also take a look at your Brake Booster check valve.
Dan
Old Jun 7, 2008 | 11:24 PM
NickBoudin's Avatar
NickBoudin
Keep the suggestions comming! The truck is still at my local dodge dealer, we brought it in, and basically told them that we dont want it back until it's fixed. So we'll see the outcome, I suppose!
Old Jun 8, 2008 | 01:10 AM
steve05ram360's Avatar
steve05ram360
search for the DIY on cleaning the tps... no need to swap it, should be in the DIY thread at the top of the forum. when you swap the IAC, I'd yank off the TB and clean it real good, most likely a cleaning will take care of it, if not then you can swap the IAC valve...
Old Jun 9, 2008 | 02:42 PM
NickBoudin's Avatar
NickBoudin
I got a call from the dealership today. They're looking into finding me a computer for it, and they're going to replace it. If it solves the problem, I pay for it. But if not, I dont have to pay for it, and they put the one I already had, back in. I wish I found the forums before I sent it to the dealership! Damn.
No one's ever heard of the Holley MTS, Hmm?
Old Jun 10, 2008 | 01:25 AM
superdak05's Avatar
superdak05
i have seen a holley dodge truck, there is a dealership in middletown ct, that built these trucks. they take a bone stock ram or dakota and throw alot of aftermarket performance parts on them. they still do this on the 08/09 models. there web site is www.holleymts.com hal the owner and dealer is a good friend of mine. there is going to be a truck show there coming up, might want to bring it down
Old Jun 11, 2008 | 07:15 PM
NickBoudin's Avatar
NickBoudin
Thanks for the link!
Old Jun 11, 2008 | 07:35 PM
superdak05's Avatar
superdak05
CONTACT THE DEALERSHIP AND THEY WILL BE ABLE TO GIVE YOU THE INFO ON YOUR TRUCK. BY THE BACK TAILGATE IT LOOKS LIKE YOU PURCHASED THE TRUCK FROM TOPOR DODGE.
