rear end noise???
Old Jun 8, 2008 | 09:17 AM
dnfd737's Avatar
dnfd737
Default rear end noise???
I was on my way home today and when I round some turns not all there is a terible clanking noise seems to be intermitant both left and right turns perhaps more frequent at higher speeds.
Any thoughts? could it be a ujoint?
Old Jun 8, 2008 | 09:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: rear end noise???
Did you forget to take the garbage can out of the bed? LOL just kidding
First thing I would check is the ujoints.
Old Jun 8, 2008 | 10:33 AM
360magnumram's Avatar
360magnumram
Yeah even if they dont have any play in them, take them off and check them. If they're real rusty they could be rusting through although it is uncommon it has happened to some of my buddies.
Old Jun 8, 2008 | 10:46 AM
dnfd737's Avatar
dnfd737
My drive shafts are very rusty as are the u-joints. I can not free the retaining nuts/bolts.They are all very tight though with seemingly no play.
I have never heard of ujoints making noise in only turns. Is this a definate possibility? I would be really releived if it were just ujoints. How ofter does the rear end/differential have a serious problem?
Old Jun 8, 2008 | 10:55 AM
zman17's Avatar
zman17
Are you sure the noise is from the rear? Typically that noise when turning is the front. And you should raise the rear of the truck to check them if you didn't.
Old Jun 8, 2008 | 11:00 AM
dnfd737's Avatar
dnfd737
Well it is definately not coming from the front. I supose it could be the middle u joint. BTW its a 2wd extended cab 8' bed. but definately not front end noise. I can feel the noise/vibration through the floor board. Hard to discribe by typeing but I think I have done a good enough job.
Old Jun 8, 2008 | 11:05 AM
zman17's Avatar
zman17
Well that answers my next ? I was going to ask for specs. on the truck! I suggest you fill out your sig and maybe more people will chime in. Some will not bother to reply if they don't know the info about your truck.
I assume you have checked the rear end grease level ?
Old Jun 8, 2008 | 11:16 AM
dnfd737's Avatar
dnfd737
yes full of oil. I just took it around the block again and could not make the truck make the noise at any particular time but it did maks a slight clicking/grinding noise from the middle/rear 1 time but couldnt make it happen again.
Old Jun 8, 2008 | 11:22 AM
zman17's Avatar
zman17
Did you raise it and check both ujoints ? It could be dirt stuck in the wheel or drum. Or a brake spring or some thing broke inside.
Old Jun 8, 2008 | 11:24 AM
dnfd737's Avatar
dnfd737
I dont have the capability to raise it I did the shake and twist method, not the most reliable but if they are really bad it should show.
