help new forum member-dead truck, trouble codes
Old Jun 11, 2008 | 08:59 AM
peterl23452's Avatar
peterl23452
Default RE: help new forum member-dead truck, trouble codes
this sucks..the forum not working and all
Old Jun 11, 2008 | 09:00 AM
peterl23452
anyway i just sunk 80 bucks into a new cps and
other goodies
new temp sensor to replace the one i broke{keep
that sensor clean people its brass and if it
corrodes it snaps right off} disconnecting all
electrical connections on the left side to check
my wires....alt,coil, injectors,temp
sensor,headlight,
ez out set to get the rest of the threads out of
the engine block
and a new air cleaner gasket, brokethe old one
when i was taking out the cps
Old Jun 11, 2008 | 09:02 AM
peterl23452
please read entire first post ....FIRST
appreciate the help and all but with the forum acting up it's a PITA to reply if i dont have to..
thank you
Old Jun 11, 2008 | 04:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the fusible links!
Old Jun 12, 2008 | 12:13 PM
peterl23452
well i replaced the cps and the truck started right up...
anyways i damaged the grommet so i didnt install that...not worried about dirt getting in right now as i'm not driving it.. i really just needed to get it running so i could get it inspected and move it from my job to my apt.
but now the truck seems slower than before...alot ...does the grommet help push the cps into position?
did i retard my timing by not installing the grommet?
will get a new grommet and reinstall with cps mod
