engine problem, please help asap
Old Jun 17, 2008 | 05:19 PM
elite1msmith's Avatar
elite1msmith
Default engine problem, please help asap
i have an 01 dodge ram 2500 4x4, 5.9 gas motor with about 100 k on it
its mis firing, and backfiring all cycliders, code says bad CMP (cam) senor or timing chain
I replaced the senor , same problem , somthing is telling me its not the chian? maybe time for convertor?
please help
Old Jun 17, 2008 | 05:21 PM
elite1msmith
Default RE: engine problem, please help asap
it dies at idle, in any gear including park so its not trans related
if u let it cool down the problem goes away, but 10 mins into driving it, when it warms up it comes right back, i could barely do 20 mph home
Old Jun 17, 2008 | 05:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
PCM!
Old Jun 17, 2008 | 05:59 PM
zman17's Avatar
zman17
You need to check IAC , TPS, and ECT.
Old Jun 17, 2008 | 06:05 PM
zman17's Avatar
zman17
Have you checked plenum ? It will also cause misfrires
Old Jun 17, 2008 | 06:07 PM
elite1msmith
yeah , i dont rmember the exact code..but it was timing chain/cam out of tollerance, or CMP (cam) sensor bad
I replaced the cam senor, still doesnt help (the old one looked bad, very rusty) same problem , i just got back from driving it about 20 mins, hard, and same thing, started dieing at idle....and if i would have keepped driving it, the motor bogs down and backfires, unless you rev it over 3000 in neutral, in drive you cant get the RPM up that high, its too bogged down , back fires, all cycliders, but if u let it cool off, the problem goes away, until it warms up again
I put a vacum gauge on it, didnt notice anything wrong
what do i check for on those sensors u listed?
Old Jun 17, 2008 | 06:09 PM
elite1msmith
plenum ? im sorry not fimilar with that?
Old Jun 17, 2008 | 06:12 PM
aim4squirrels's Avatar
aim4squirrels
Check all sensors that are operating in closed loop mode. A bad cat can screw with O2 sensors.
Download the FSM and look around pages 466-468.
Old Jun 17, 2008 | 06:13 PM
aim4squirrels
Not to be a jerk, but are you sure you changed the Cam sensor and not the Crank sensor?
Old Jun 17, 2008 | 06:15 PM
elite1msmith
cam sensor located in the distributer, after rmoving the cap and rotor, it pulls staight up
