Truck dies when put in gear, idles fine in park and Neutral.
Old Jun 22, 2008 | 03:31 PM
TRRDK's Avatar
TRRDK
Default Truck dies when put in gear, idles fine in park and Neutral.
Well I have tried to research this before posting but I can't seem to find the same problem I have already posted. I have a 2000 5.9L 1500 extended cab and the weirdest thing is happening. The truck will idle perfect as long as I don't put the truck in reverse or drive. I can put it in neutral and it will run all day as well. As a matter of fact I ran it in neutral while a friend helped me tow it home. I noticed when I went to stop at the red light it studdered and then died. I am at a loss, there are not any codes displayed either with the OBD II reader nor with the on-off-on-off-on method. I had the Torque Converter replaced a couple of months ago and noticed a vacuum leak after AAMCO worked on it. Can a vacuum leak cause this? Any help is greatly appreciated, I have had some great reference material from this site to fix past problems.....
Old Jun 22, 2008 | 03:35 PM
timsalas's Avatar
timsalas
Default RE: Truck dies when put in gear, idles fine in park and Neutral.
sounds like yet torque converter is having issues, take it back to aamco it should still be under warranty yes?
Old Jun 22, 2008 | 03:41 PM
8t5gt's Avatar
8t5gt
+2 on locked up converter
Old Jun 22, 2008 | 04:10 PM
TRRDK's Avatar
TRRDK
I'll have it towed there hopefully next week. I was hoping it was something easier but it does make a lot of sense. Thanks for the replies, everyone here is great!!! I'll post again and keep everyone informed.....
Old Jun 23, 2008 | 01:24 PM
ltbordo's Avatar
ltbordo
just fixed the EXACT problem on my diesel ram 3500 dueley. What are you idling at in park/neutral? I'll bet you're near the 250-500rpm range. You need to be around 800 in park/idle and 525 in drive with the A/C on. There are 2 idle screw on your injector pump near the BACK of the pump, the high speed idle is factory set and you don't need to mess with it. The LOW idle stop bolt is a accessed from the top and a locking nut accessed from the bottom (both hard to get to unfortunately) Loosen the locking nut from the bottom (10 mm socket with a long extension) till it is just barely on the bottom threads of the adjusting bolt. Then (with a helper holding down the pedal to give you room to get to it) loosen i.e. turn COUNTER clockwise from the top to RAISE the adjusting bolt a couple of turns with a 10 mm open end wrench. start truck, check idle.....repeat until truck idles at about 800 rpm in park/idle. Remember to tighten the locking nut when finished while holding the adjusting bolt in place with your wrench. (pretty much a 3 man job!)
Old Jul 16, 2008 | 08:48 AM
TRRDK's Avatar
TRRDK
Sorry it has been a while since I updated my problem. AAMCO told me the T/Q came apart and that was the problem. It was replaced under the warranty so I amgood now. Amazingly enough my vacuum leak that developed after the first time they worked on it is fixed now as well!! Anyway thanks to everyone who replied with helpful information!!! I look forward to possibly helping someone out the way I have been helped here some day..
Old Jun 18, 2012 | 02:26 PM
patrick 1988 dodge's Avatar
patrick 1988 dodge
what do T/Q mean
Old Jun 18, 2012 | 06:36 PM
I am thinkin' torque converter.
Old Jun 19, 2012 | 12:31 AM
gdstock's Avatar
gdstock
Usually referred to as TC.....
Old Jul 15, 2014 | 04:21 PM
nick0584's Avatar
nick0584
Default I have the same issues just wanted to know if yours went away when engine warmed up
I have the same issuewanted to know if yours went away when engine was warmed up
