The case of the leaning truck...
Old Jun 27, 2008 | 02:15 PM
mstephen89's Avatar
mstephen89
Default RE: The case of the leaning truck...
no, they are a very simple fix, that you can do with normal tools, and either a friend or two or a bottle jack and some concrete blocks.
Old Jun 27, 2008 | 03:00 PM
jasonw's Avatar
jasonw
Site Moderator
Body mounts look perfectly fine. None broken, very little rust where they start on the frame, very little where they meet the body. Could it be a broken leaf spring? They look fine, but can they go bad and you not be able to tell until you take it off and/or replace it?
Old Jun 27, 2008 | 03:16 PM
mstephen89's Avatar
mstephen89
i thought that the frame was level
Old Jun 27, 2008 | 03:23 PM
jasonw's Avatar
jasonw
Site Moderator
It appears to be... in the front around the cab where I first measured.
So I got underneath and did some more measuring, just in the back.
I measured from the top of the wall of my bed to the top of the cab. 1/2" lower on driver's side. So the problem does appear to be in the rear.
I measured from the rear axle itself to the frame. Approximately 1/4" lower on driver's side then passenger.
I also measured from center of the leaf springs to the bed. 1/2" lower on driver's side.
Old Jun 27, 2008 | 03:47 PM
Aubrey's Avatar
Aubrey
I'm confused. Your bed doesn't sit level? The entire truck is not level? From the frame down is level but there up it is not?
My bed does not sit level because the floor is cracked up by the cab. It's kind of wobbily.
Old Jun 27, 2008 | 03:52 PM
aim4squirrels's Avatar
aim4squirrels
Take Pics Jason, maybe we can see what's going on.
Old Jun 27, 2008 | 04:13 PM
mstephen89's Avatar
mstephen89
aubrey would you take some pics of your truck, your sig sounds awesome
Old Jun 27, 2008 | 05:25 PM
johnjokela's Avatar
johnjokela
you didcheck your tire pressure right
Old Jun 27, 2008 | 05:29 PM
jasonw's Avatar
jasonw
Site Moderator
Measurements I've taken so far, comparing both sides:
Front (cab)- [ol][*]Coil Springs - No difference in height.[*]From top of wheel well to bottom of tire - 1/2" lower on driver's side.[*]From frame underneath cab to ground - No difference in height.[*]Top of cab to top of wall of bed - 1/2" lower on driver's side.[/ol]Rear (bed/box)- [ol][*]Leaf springs to bottom of bed - 1/2" lower on driver's side.[*]From top of wheel well to bottom of tire - 1/2" lower on driver's side.[*]From axle to frame - 1/2" lower on driver's side.[/ol]
And yes, my tire pressure is fine. 39.5-40.5 psi per tire hot (measured it yesterday after driving home from work). Cold its about 38psi.
Old Jun 27, 2008 | 05:52 PM
mstephen89's Avatar
mstephen89
measure from the ground, up to the bottom of the doors
It sounds like the body is level, but the bed and the fenders are not level. Post some pics, I think that will help us all out
