oil on my spark plug??
Old Jul 1, 2008 | 02:00 AM
oakleytw's Avatar
oakleytw
Default oil on my spark plug??
My 97 5.2 ram its running a weird and im getting a mis fire code all the time on cyl5the service engine light is always on and has started 2 blink every now then.The spark plug has oil on it.... all others are fine, can eny 1 give me advice??
Thanks Tom,
Old Jul 1, 2008 | 04:21 AM
Dodgeman000's Avatar
Dodgeman000
Default RE: oil on my spark plug??
I think you valve cover gasket is leaking? Or you valve guide is leaking. As for the miss fire your spark plug is all fouled up with oil so that may be why you have the miss fire.
Old Jul 1, 2008 | 02:34 PM
oakleytw's Avatar
oakleytw
I bought the truck a year ago and I put new heads on it, now 23,000 miles later.Im gettingoil on the spark plug on the inside of the block, not were the wires snap on. When the misfire happens with the torqueconverter locket up whileim driving I can really feal itthrow the truck, tap the brake and it goes away.[/align][/align]im gnu take my valve cover off and check my valve stem seals today[/align]
Old Jul 1, 2008 | 02:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
On a 97 I bet the plenum is no good if it's never been replaced.A bad valve guide or seals can cause that too, but I bet plenum gasket.
Old Jul 1, 2008 | 02:42 PM
zman17's Avatar
zman17
And as far as the blinking CEL goes, check the cat.
Old Jul 1, 2008 | 04:22 PM
oakleytw's Avatar
oakleytw
I have already replaced the plenum gasket and I look down the throttle body and its clean. My cat was hollowed out years ago and never gave me eny problems. Im taking my valve cover off right now..
Old Jul 1, 2008 | 04:52 PM
wvjefo's Avatar
wvjefo
Bad ringswill get oil on plugs
Jeff
Old Jul 1, 2008 | 07:44 PM
oakleytw's Avatar
oakleytw
well my valve stem seal was not quite oncorrectly on theexhaust valve, however i was able to get it back in place. i orderednew valve stem seals be here tomorrow i put it back together took it for a ride and got 2 codes again cyl 5 misfire and multiple misfire. bummer[/align]
Old Jul 1, 2008 | 08:14 PM
dhvaughan's Avatar
dhvaughan
are you going to pull the heads to replace the seals or do the air pressure trick or the string in the cylinder trick ?
Old Jul 1, 2008 | 09:04 PM
Shawn86's Avatar
Shawn86
I've got kindof the same thing with my number three cylinder, cept the miss was caused by a bad wire. I just pull the plug 'bout once a month and spray it down with some carb 'n' choke and put her back in, runs like a champ! Eventually I'll get around to checking the rings but I'm saving up for a tranny right now, any suggestions...
AND I DONT WANT TO WAIT OVER A DAY FOR AN ANSWER!!!!!!!!!!!!!!!!!
Sorry couldn't help it!
