One 12v outlet working the other does not
Old Jul 9, 2008 | 05:42 AM
iwhitne's Avatar
iwhitne
Default One 12v outlet working the other does not
98 ram 1500.. has 2 12v outlets.. the one by the floor works... the one by the air bag shut off does not.... any clues?!
Old Jul 9, 2008 | 06:53 AM
lxman1's Avatar
lxman1
Site Moderator
Default RE: One 12v outlet working the other does not
Perhaps the plug came off of the back of the outlet?
Old Jul 9, 2008 | 10:51 AM
cnorris's Avatar
cnorris
Fuse blew. Check the fuses.
Old Jul 9, 2008 | 10:58 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
ORIGINAL: cnorris
+1
Fuses are the very first place to check. Usually thoseplugs dont go bad easily unless they've seen alot of wear/tear. However, it's really easy to overload/blow a fuse in them.
Old Jul 17, 2008 | 08:55 AM
iwhitne's Avatar
iwhitne
where is the fuse located for that outlet.. everything else on the dash works.. so i would guess this has it's owe fuse... located where?
Old Jul 17, 2008 | 01:47 PM
dsieber's Avatar
dsieber
The fuse for the ciglighter outlet is in the fuse panel on the driver side. The 12-volt outlet fuse is in the fuse box under the hood on the drivers side.
Old Jul 17, 2008 | 01:48 PM
jasonw's Avatar
jasonw
Site Moderator
I think its in the PDC (Power Distribution Center) under the hood. Driver's side, between the battery and the cab. Big black box.
Otherwise, it will be in that little side panel on the left side of the dash by the door.
Old Jul 17, 2008 | 05:24 PM
RangerMateo's Avatar
RangerMateo
2
Had the same problem with my 97 and it was the fuse under the dash. I looked at my inside fuse box and was baffled too. It wasn't till later when I was installing a hotwire for my inverter that I noticed the label on the fuse box...grr
Old Nov 25, 2008 | 08:15 AM
iwhitne's Avatar
iwhitne
Thank you guys! Both of them just went so I will be checkin into it asap.... cause my gps doesn't run for long without some power!
