Front end clicking
Old Jul 12, 2008 | 05:48 PM
lupenbeast's Avatar
lupenbeast
Default Front end clicking
Hi all, new to the forum, MOPAR for LIFE! Have a clicking sound from front left side, not sure exactly where. Clicking stays in time with speed, going slow...slow click, etc. Doesnt happen while turning, just straight line. Any thoughts?
Old Jul 12, 2008 | 07:12 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Default RE: Front end clicking
my first guess would be u-joint, second guess would be your bearing, third guess is brake related.
Old Jul 12, 2008 | 07:24 PM
jasonw's Avatar
jasonw
Site Moderator
My first guess would be a u-joint as well. When brakes act up, they usually squeak or something similar, usually not a click, but that could be a possibility as well I suppose.
Old Jul 12, 2008 | 07:39 PM
lupenbeast's Avatar
lupenbeast
U joints only have 150 miles on them and brakes including rotors done 2 weeks ago. I kinda thought maybebearing, cause left side shaft starting to leak.
Old Jul 12, 2008 | 07:54 PM
hutch1973's Avatar
hutch1973
All u-joints changed, as in both drive shaft and the front knuckle?
Old Jul 12, 2008 | 08:15 PM
lupenbeast's Avatar
lupenbeast
just the front, havent done the drive lines yet
Old Jul 12, 2008 | 10:23 PM
98DodgeRam1500
ORIGINAL: lupenbeast
your bearings have no relation to your seals. they are seperate units. The bearings on the rams go commonly. Mine went at 104K, both of mine were REALLY bad. But mine sounded like a groaning sound...
my ranger used to go through u-joints on the rear drive shaft all the time, and I cold hear it ticking/clicking when it was time to replace it.
edit:
Oh, and my driverside seal is leaking also, that started around 107K... I am just going to keep it topped off and try a lucas oil additive to help slow the leak...
Old Jul 13, 2008 | 03:44 AM
Shawn86's Avatar
Shawn86
That tick that your talking about was the reason why I joined this forum, and that was almost two years ago I think! On mine it only does it when I'm on the brakes and it is consistent with the speed of the vehicle. I've replaced the axels seals, rotors, u-joints, pads,anti-rattle clips on the calipers, and lubricated the hell out of every moving thing under thereand lathered the stop squeek on the backs of the pads. Still ticks! Next is the calipers, drivers side has a small leak anyways. Let me know if you find out what it is, Its starting to really 'tick' me off!
Old Jul 13, 2008 | 03:11 PM
98DodgeRam1500
ORIGINAL: Shawn86
mine has a tick sound also, it goes one tick with each revolution of the tire. i can only hear it when i am driving with the windows down, and with something on the side to reflect the sound back... maybe its something in the CAD unit... I don't really care if it ticks, I looked for the tick and cant trace it back to anything that would cause a safety issue or a breakdown weak spot. (also a new bearing on that side).
Old Jul 13, 2008 | 09:08 PM
Shawn86's Avatar
Shawn86
yep, been trying to track it down fort almost two years now! Hasn't gotten any better or worse. Eventually I'll have to replace whatever part it is and then we'll know!
