POP
Old Jul 12, 2008 | 05:52 PM
greenmachine's Avatar
greenmachine
Default POP
Does or has anyone had, a single popping sound that they could also feel in thier steering column when stepping on the brake? This does not occur when they are released. I assumed it was a loose steering column but everything is tight. Nothing obvious anywhere else.
Old Jul 13, 2008 | 07:08 PM
greenmachine
Default RE: POP
Nobody? Ideas?
Old Jul 13, 2008 | 07:14 PM
Viper37's Avatar
Viper37
Default RE: POP
YES! My truck does the exact same thing. Anyone have any idea's?
Old Jul 13, 2008 | 07:26 PM
Magnumpwr16's Avatar
Magnumpwr16
Default RE: POP
Mine too.....sometimes even when I turn the steering wheel I'll get a POP from it occasionally
Old Jul 13, 2008 | 08:24 PM
DPR250R's Avatar
DPR250R
Default RE: POP
http://www.rocksolidramtrucksteering.com/
Old Jul 14, 2008 | 03:36 AM
greenmachine
Default RE: POP
The only problem here is that my steering has no play. It also does not a clunck, rattle, or any type if shimmie. One single pop which will resonate through the steering column. This ONLY happens when you step on the brake. Stumped.
Old Jul 14, 2008 | 08:27 AM
DPR250R's Avatar
DPR250R
Default RE: POP
I have the pop through the column too. Sometimes when I hit the brakes, when turning, over bumps, off-road... whenever it feels like it. It feels like its only in the column.
I was going to try a new steering shaft til I found that part. I keep meaning to order it but have not gotten around to it. Need to do my evap first...
I will report back after i install it.
Old Jul 14, 2008 | 10:02 AM
Mowhawk's Avatar
Mowhawk
Default RE: POP
Prob makes no sense but just throwing idea out there.....air pockets in powersteering?
Old Jul 14, 2008 | 10:44 AM
Aubrey's Avatar
Aubrey
Default RE: POP
Only pops during braking foward or in reverse? Do you have a lift? Not saying this is your particular problem but my Skyjacker upper and lower arms with their super soft poly bushings wear out after 25k miles. When they wear, you'll hear and feel a pop as they move. Yours sounds different but, having a lift or in a particular motion might help narrow it down.
Old Jul 14, 2008 | 10:58 AM
lastrights's Avatar
lastrights
Default RE: POP
my cousin has a dodge ram 98 and his did that ,and it ended up being a tranny mount
