squeek problem....
Old Jul 21, 2008 | 10:45 PM
bigmudder77's Avatar
bigmudder77
Default RE: squeek problem....
any rocks or dirt in the pads or rotor? what about defected factory parts?
or suspention? or what about wheel or axle hub
Old Jul 21, 2008 | 10:54 PM
Mowhawk's Avatar
Mowhawk
honestly dont know, ive had it to many shops nd they all say everything is good
Old Jul 22, 2008 | 07:44 AM
bigmudder77
does it make the noise when you turn the wheel?
Old Jul 22, 2008 | 09:17 AM
Silver_Dodge's Avatar
Silver_Dodge
Check this TSB. I had this on my '99.
http://dodgeram.info/tsb/1999/03-06-99.htm
Old Jul 22, 2008 | 09:59 AM
Mowhawk's Avatar
Mowhawk
No sound when i turn wheel, and thanks silver but i have no idea if this pertains to me or with what its talking about. Are theyre any pics i could look at? And would it still apply to me if squeek comes and goes and occurs at high speeds too?
Old Jul 22, 2008 | 10:09 AM
Mowhawk's Avatar
Mowhawk
also i dont think its this due to the fact that as soon as i step on breaks the squeek stops
Old Jul 22, 2008 | 10:29 AM
Aubrey's Avatar
Aubrey
I had a similar problem and it was the front pads. You have to take them off to see but the retainer springs weren't holding them tight.
Old Jul 22, 2008 | 03:24 PM
Mowhawk's Avatar
Mowhawk
ill check that out thanks.
Old Jul 22, 2008 | 07:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the caliper slides/pins are moving freely
Old Jul 23, 2008 | 12:54 AM
badram1500's Avatar
badram1500
I ran into a truck at work doing the same thing. This will sound strange but the cure to that one was lubing up the axle seals had another tech tell me about it. Just sprayed some penetrant into the tube and the squeak was gone!
