TRANNY KIT
Old Jul 27, 2008 | 01:46 PM
wildwolf59's Avatar
wildwolf59
Default TRANNY KIT
ok guys im gona have this dodge mechanic i know rebuild my tranny and was wanting to know what would be the best kit to buy to put in my tranny? Also should i put a new torque converter in it or not?...i am gona put the deeper pan on it and i have the off-roAD so it has the tranny cooler already....right now i can drive it but it wont shift out of first gear...i can hear the loose band in there making noise so its not like parts are grinding and falling into my pan...i dont want to go with any oem parts or kits so if you guys can give me some ideas i would be grateful!!!!...thanx!!!!
Old Jul 27, 2008 | 02:36 PM
padodgeram's Avatar
padodgeram
Default RE: TRANNY KIT
shift kit would be transgo HD2 , And yes on the new TQ converter , make sure your guy looks over the overdrive unit real good make sure there is no problems with it..
Old Jul 27, 2008 | 03:03 PM
wildwolf59's Avatar
wildwolf59
if there was something wrong with the overdrive unit what would i replace on it?...or should i just replace it anyway?
Old Jul 27, 2008 | 05:52 PM
xskylinedx's Avatar
xskylinedx
I can say that everyone i've talked to has regretted rebuilding thier factory tranny instead of buying a built one from dr.evil, aps, etc.
(yes i know someone is going to get on here, read this, then tell me how much they love thier rebuild...... don't care.)
Old Jul 27, 2008 | 09:21 PM
98DodgeRam1500's Avatar
98DodgeRam1500
ORIGINAL: xskylinedx
I don't care, that you don't care. Lots of us here have had them rebuilt. Mine was rebuilt by a reputible transmission shop and it has been fine. I don't tow much, but I have towed a Pequea C2500 dump trailer from time to time with a small load and its been flawless.
If I had over sized tires, and was going to tow, or load the transmission a lot, then YES get the Dr Evil...aps...etc. if its your daily driver, and weekend warrior truck, then find a local shop that offers a 1-3yr warranty on their work.
Best of luck.
Old Jul 27, 2008 | 10:26 PM
wildwolf59's Avatar
wildwolf59
yeah i wont do a lot of towing just mainly daily driver and a hunting truck and my mechanic is giving me a full year warranty so i will try to tow some things in that year to see if it will hold up!....costing me 900.00 for the whole rebuild with a rebuilt torque converter and all new overdrive parts maybe up to 1100.00 but notmore than that so i think i will try it and see!
Old Jul 27, 2008 | 10:48 PM
xskylinedx's Avatar
xskylinedx
ORIGINAL: 98DodgeRam1500
Best of luck.
Congrats! you were THE ONE. thanks. at least your finally not whining about your truck and saying something positive. again, i said i don't care because i didn't want an argumenative response. so thanks again.
Old Jul 27, 2008 | 11:00 PM
98DodgeRam1500
Wasn't disagreeing about a dr evil, or apsbeing the best option, its just the most expen$ive option.
Yes, lucky me, the Only One to ever have their transmission rebuilt and ihave t still work afterwards. I can't figure out how all these transmission shops survive if they can't rebuild a 518 transmission... they have been rebuilt so many times, i am sure most shops can do them in the dark, upside down, with one hand behind thier backs.
Old Jul 27, 2008 | 11:16 PM
padodgeram's Avatar
padodgeram
ORIGINAL: wildwolf59
The OD unit is the weakest part of the trans.. With that said , im sure your guy knows what to look for .. shift kit will help alot , plus clutch bands , you can go wild (all heavy duty) ..for 1200 bucks your getting the basic rebuild , hell i spent that on parts alone and i rebuild my trans with a new OD unit , new trans line .(( MAKE SURE YOUR TRANS GUY MAKES SURE YOUR ANTI DRAIN BACK VALVE IS CLEAR OR CLEAN , OR GET NEW . IF CLOGED IT WILL BURN THE TRANS UP))) deep trans pan helps , and full syn trans fluid...
Old Jul 27, 2008 | 11:20 PM
98DodgeRam1500
ORIGINAL: padodgeram
drain back valve, is that the check valve? If so, the place that did mine said it was best to remove or drill it out. Whats the best to do, remove or just replace?
