Front wheel hub
Old Aug 8, 2008 | 08:03 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by Sehr916
when I was jacking the truck up, as the tires left the ground the bottoms rotated inward. Does this mean anything?
no, that's normal.
Old Aug 10, 2008 | 08:18 AM
98DodgeRam1500's Avatar
98DodgeRam1500
Originally Posted by dhvaughan
no, that's normal.
What? dhvaughan you are kidding right?
Mine did once and I had to replace both of my hubs. Now they are solid and do not move when off the ground. If you have good/new hubs and it does that, then you got bad joints.
For example... http://www.youtube.com/watch?v=Iqbc7Ld7cvY&NR=1 clearly bad bearings.
Here you can see on a dakota http://www.youtube.com/watch?v=ZbkwdoOPcvM
Last edited by 98DodgeRam1500; Aug 10, 2008 at 09:34 AM. Reason: Added link for video.
Old Aug 10, 2008 | 08:02 PM
Sehr916's Avatar
Sehr916
Thanks for those videos. When I meant the tires rotated I didn't mean like in those videos. I checked the tire for any play and it was fine. I think the rotation I'm noticing is the control arms lowering and the suspension extended making the tires look like they are rotating in
