Front wheel hub
Old Aug 4, 2008 | 11:27 PM
mcsd913's Avatar
mcsd913
Post How do you tell if a trucks rear abs or just abs?
Well before i wreck and die.I gotta replace my wheel hub but idk if its rear abs only or both...2001 5.2 318 4wd
Old Aug 5, 2008 | 04:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Just see if you have a wire running to the back of the front hubs.
Old Aug 5, 2008 | 04:56 PM
motorbrreath's Avatar
motorbrreath
+1. most likely an 01 is gonna have rear abs. Check under your hood or in your glovebox for the list of features and see if that says it.
Old Aug 6, 2008 | 10:36 PM
mcsd913's Avatar
mcsd913
yeah it wasnt front abs....Hell im not gonna lie...My bearing was complete gone....My buddy who helped me put it on said damn you were lucky to make it over here...Thanks guys once again.
Old Aug 6, 2008 | 10:48 PM
98DodgeRam1500's Avatar
98DodgeRam1500
both mine went, one was worse than the other.
Also had one u-joint replaced, should have had them do both, and while they had both bearings out, I should have had them replace the axle seals.
glad you are safe again...
Old Aug 7, 2008 | 09:12 AM
dhvaughan's Avatar
dhvaughan
glad that didn't happen.
Old Aug 7, 2008 | 08:22 PM
Sehr916's Avatar
Sehr916
I have a quesiton regarding how you know if your hubs/bearings are going out?
I have a 2WD (2000) and I'm getting noise from the front passenger side suspension. It can be felt underneath the floorboards too. Any ideas?
Old Aug 7, 2008 | 09:13 PM
dhvaughan's Avatar
dhvaughan
jack up the front. grab the tire out on the edges. wiggle left/right. wiggle top/bottom. should be no wiggle movement.
a thump sound under the feet of driver or passenger is lower front shock bolt not tight. must be 100# torque which is a helluva lot.
Old Aug 7, 2008 | 11:23 PM
Sehr916's Avatar
Sehr916
I'll give that a try and see how it goes.
I will also try and re torque the shock bolts
Edit: The lower shock bolt was loose. I tightened it to spec (105) so I will let you know if that fixes anything.
I didn't notice any reasonable play in the tire but I did notice, when I was jacking the truck up, as the tires left the ground the bottoms rotated inward. Does this mean anything?
Old Aug 8, 2008 | 07:54 PM
Sehr916's Avatar
Sehr916
That fixed it. Thanks a lot
