Ball joint replacement 2wd
Old Aug 28, 2008 | 09:15 PM
aim4squirrels's Avatar
aim4squirrels
Default Ball joint replacement 2wd
Hey guys, got a question for you.
I was under the truck inspecting the suspension to find a rattle I have when I hit a bump. Anyway, i noticed the dust boots are badly cracked on all 4 ball joints, which means I might be replacing them soon.
I was checking out rockauto, and noticed that the 2wd and 4wd ball joints are different in that the 2wd's have a flange that is held on by 3 and 4 massive "rivets"
The replacements use bolts which can be tightened, but how do I get the rivets out? My first thought is angle grinder them flat and punch them out with a hammer and bolt. Then i should be able to remove the ball joint correct?
Old Aug 28, 2008 | 09:50 PM
the_mechanic_33's Avatar
the_mechanic_33
New Member
Use an air hammer with a flat spade bit (sharpen when needed) an hit the rivit head on angle with a wiggle motion when u get a bite under it (careful not to gouge the control arm) and bam head will shoot off (careful wear safty glasses) then u can punch rivet through or repeat on other side.
Old Aug 28, 2008 | 10:34 PM
aim4squirrels
No air hammer available, any other suggestions?
Old Aug 28, 2008 | 10:44 PM
dodgeram07's Avatar
dodgeram07
thats weird my 95 don't have rivets. but many way im have a hard time picture it so.... but do you think you can drill them out
Old Aug 28, 2008 | 10:53 PM
the_mechanic_33
New Member
drilling take forever and ur arms hurt and u cuss alot but sure it can be done.have had great success with the air hammer.took me 3 hrs to drill one side and 15 mins with hammer and sharp bit.
Old Aug 28, 2008 | 11:25 PM
dodgeram07's Avatar
dodgeram07
the mechanic 33- Were you using good quality, sharp drill bits and oil?
Old Aug 29, 2008 | 08:42 AM
aim4squirrels
Actually, If I use the angle grinder on the side with the flange it shouldn't matter, since there's a new flange on the new ball joints, damage doesn't really matter.
Old Aug 29, 2008 | 05:37 PM
the_mechanic_33
New Member
titanium nitride with a drill doctor. Yea u could grind then drill i suppose.
