Help! Before junk yard closes
first thing to remember is you must kill thge rust and thats very easy, after you have sanded the rust spots give them a good bath with muratic acid to kill the rust , just apply it to the spot let it stand for a few min. and rinse it off folowed be a good soap bath. BE SURE TO WEAR PROTECTIVE CLOTHING WHEN DOING THIS AND EYE PROTECTION. If you have a sand blaster to use its even better. Even the spots back up to the surface with a good spot filler sand them smooth with a pice of 250 grit sanding paper glued to a flat piece of wood and reaply primer to evidence that all scratches are gone then a good wet dry paper keepin it wet with water mixed with baby soap. It should look great. good luck terry-----------tboss
$35??!!!! That guy would be fired on the spot if he sold a door that cheap at the yard I work at lol The door handles are worth more then that each lol I am pretty sure the doors will be the same (94-01), but I do know that some later years (98-01) have different plugs for the window switches. You can at the very least use the shell and transfer your guts over if need be.
Thanks for the tips tboss.
Smile
And CC, Last year I got a perfect tailgate off one for $25 lol . And it was even the right color.
Smile
