big problem..need answer
Old Sep 6, 2008 | 11:32 AM
APA228's Avatar
APA228
In keeping with the KISS principle, have someone stand by your tailpipe while you are cranking the engine and see if there is pressure coming out the end. You stated you were pulled out of water/mud backwards. Odds are mud got into the pipe and solidified while you were driving. As kids we would put a potatoe into someones exhaust pipe and they would drive for a bit and the car would crap out. They will not run if they can't breath. Good luck!
Old Sep 6, 2008 | 01:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I have to agree! The exhaust is plugged. As far as it overheating, that could have caused another prob. But I would remove the exhaust, cat back and see how it runs.
Old Sep 7, 2008 | 09:17 AM
meanwhitemopar's Avatar
meanwhitemopar
ok well i took everyones thoughts nd put it into one, i unpluged the front o2, still ran the same but with it pluged iin or not, when i removed the o2 sensor, NOW BEING ABLE TO BREATHE, truck runs fine, doesnt have the power it should but it will go and doesnt overheat now. so i am going to do alittle work on the truck either today or tomorrow, i am cutting th eexhaust just after the cat, gutting it, and putting a single 2 1/2 inch pipe on and stopping it before the axle, should breathe just fine with that, and it sould sound good too
Old Sep 7, 2008 | 09:18 AM
meanwhitemopar
oh yea, i will see what i can do about letting you guys know how it goes, and posting a video of the new exaugst
Old Sep 7, 2008 | 12:06 PM
dillonjm's Avatar
dillonjm
Yeah, let us know how it goes, glad you're getting it taken care of.
Old Sep 7, 2008 | 02:27 PM
meanwhitemopar
ok guys, figured it out, the truck had a broken (inside) cat, and water in the exhaust, i cut with a sawsall, cleaned it out, runs awesome, was really load with no cat though so i welded that back on
Old Sep 7, 2008 | 02:35 PM
zman17's Avatar
zman17
Glad you got it figured out! And thanks for the update, that seems too hard for most people.
Old Sep 7, 2008 | 09:30 PM
APA228's Avatar
APA228
Glad it was just the plugged exhaust. They sure do run nice when they can breath right.
