Lower gears
Old Sep 15, 2008 | 10:13 PM
Visious 318's Avatar
Visious 318
Exclamation Lower gears
I am looking into putting 4.56 Yukon gears front and rear in my 97 1500 due to the 33's and the 3.50 gears are way to high and the 318 just don't have to shift in its pants to turn them in the mud unless in low side. My qeuston is I want my RPM to be around 2250-2400@70mph am I their with these gears and is this a weak gear set? I mean will they handle some off road and pulling?
Old Sep 15, 2008 | 11:34 PM
troberts's Avatar
troberts
http://www.ringpinion.com/Calc_RPM.aspx
Use this calculator to figure were you want to be. 4.56 might be high to be cruising 70-80 mph to some people. If your staying off road, well then go big.
Hope the calculator helps.
Old Sep 15, 2008 | 11:46 PM
Visious 318
Comes out to running 2438@70mph with 4.56 gears and 33's
Does anyone run these gears how strong are they?
Old Sep 16, 2008 | 09:17 PM
Visious 318
Front Dana 44
Yukon Ring and pinion $208.83
Master installation kit $163.15
Rear Chrysler 9.25
Yukon ring and pinion $287.37
Installation kit $124.14
Axle bearings and seals $30
Detroit True Trac Locker $499
Is their any parts i am forgetting here that you can can think of? Besides oil.
Old Sep 16, 2008 | 09:24 PM
Rockyhigh360's Avatar
Rockyhigh360
Stay away from the jap crap! Spend the money and run Dana Spicer, Richmond or Precision. Yukon and Genuine are what you pay for....cheap. Go ahead and throw in some Chromoly axle shafts while your in there, well worth the security.
Old Sep 16, 2008 | 09:55 PM
dhvaughan's Avatar
dhvaughan
replace the front axle seals while you're in there.
consider replacing front axle u-joints while your doing the seals.
Old Sep 16, 2008 | 09:57 PM
aim4squirrels's Avatar
aim4squirrels
Doesn't the D44 need a new carrier to run anything past 3.92?
Old Sep 16, 2008 | 10:22 PM
pcfixerpro's Avatar
pcfixerpro
You can get the thick gears. Can't say i've heard too much about them, but... it will save you a couple bucks instead of buying the new carrier.
Old Sep 17, 2008 | 07:49 PM
Rockyhigh360
You definatly will need the bigger carrier past 4.11's. I would recomend a detroit full soft locker, it works great with 35's. I highly recomend you do as much research before buying ANYTHING. Ask around and don't cut yourself short on parts. You do not want your gears, carrier, axels, or bearings breaking on the trail, trust me. Spend the extra cash and do it once!
Old Sep 17, 2008 | 10:03 PM
Visious 318
Rockyhigh360
"I highly recomend you do as much research before buying ANYTHING. Ask around and don't cut yourself short on parts. You do not want your gears, carrier, axels, or bearings breaking on the trail, trust me. Spend the extra cash and do it once!"
That is what I am doing. Trying to get feedback from people and upgrade anything that is weak while i'm there. I had a shop try to talk me into reusing my old bears on the new stuff I told him if it comes out it gets replaced if it comes new it WILL be replaced and I want all the old stuff. As far as axles I am reusing them for what this truck is used for I will never break one. I am changing the gears becuz the truck is so high geared i get better milage out of OD than in. 33's+3.50 gears and i'm tired of only having a defroster due to no vacum cuz the engine is working so hard to keep the truck moving and it shifting in and out of OD at 70mph becuz the rpms are 1400. That and This will wake up this truck to run the way it should, the power is thier just to high geared to feel it.
