98 3500 RAM LOADING UP and missing with low idle and smoke
Old Nov 18, 2013 | 09:03 PM
JRod17's Avatar
JRod17
i just posted a simular post. I replased both iac and tps and it didn't change a thing. From what i found it could be the egr transducer, if yours has it. min is plugged hopfuly that will do it.
Old Nov 19, 2013 | 07:41 AM
joulian's Avatar
joulian
I replaced IAC and TPS long time ago ( kinda gave up after that ) until brake booster went out and then I started trying to figure it out again. Is that EGR transducer over behind passenger headlight? If so i replaced it a long time ago. That didn't work.
Old Nov 19, 2013 | 12:45 PM
97 Shouldn't even have EGR.
Old Nov 19, 2013 | 11:48 PM
dhvaughan's Avatar
dhvaughan
around the passenger headlight area was probably evap purge solenoid or evap leak detection pump.
