Marvel Mystery Oil in gas
Old Sep 22, 2008 | 01:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default Marvel Mystery Oil in gas
Well, got to say I'm impressed. Figured I'd try it after reading the RP AND MMO thread. I've ran a few tanks with the recommended 4oz to 10 gals. fuel, and I'm amazed how good the motor runs. Smoother idle, smoother acceleration (had a small hesitation on acceleration pre MMO. Gone!) . Smoother cruising at all speeds. And better throttle response at higher RPM's also. I use Mobil One not RP (I did not change the oil to try the MMO, it's not due). And as far as any increase in MPG goes, I could care less, the motor runs so much better it's ridiculous as far as I'm concerned(and I use Techron in it regularly). It only gets 10 now if I'm lucky, and since I already use the Mobil One, there is no way using RP will bring it up significantly anyway. All I care about is how much better it runs. Call me crazy, but I think it's worth the extra bucks to stick it in there every couple tanks , just for the performance increase.
Old Sep 22, 2008 | 02:43 PM
motorbrreath's Avatar
motorbrreath
i use it in my oil and gas, mixed with a little seafoam.
my neighbor used it at every fill up in his 88 cherokee. 354K on the clock.
Old Sep 22, 2008 | 02:53 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
As stated in the thread you read, it lubricates the injectors, which is very important.
Old Sep 22, 2008 | 03:42 PM
zman17's Avatar
zman17
Unless I'm wrong, isn't the Techron(which like I said use frequently) and Lucas that I have tried a few times suppose to do that too?
Old Sep 22, 2008 | 10:57 PM
iwhitne's Avatar
iwhitne
TOLD YA SO!!!!!!!!!!!!!! HAHAHA love this stuff!!!!
Old Sep 23, 2008 | 03:46 AM
Dakine69302's Avatar
Dakine69302
i tried finding the post you were talking about but couldn't. What are you mixing in with the gas? tell me more.
Old Sep 23, 2008 | 03:57 AM
jasonw's Avatar
jasonw
Site Moderator
Marvell Mystery Oil. Several different people have claimed that it lubes the injectors and helps with mileage, overall engine condition, etc.
Enough people here that I trust have come forward saying its helped them, that I am going to pick myself up a bottle next time I'm in an auto store.
Old Sep 23, 2008 | 09:07 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Yes, but Techron and Lucas also have additives to burn out carbon deposits in the combustion chamber.
Old Sep 23, 2008 | 02:21 PM
charlie1935's Avatar
charlie1935
I use two cycle oil that meets TCW3 standards in my trucks. One ounce per five gallons of gas. In the 87 318 the idle smoothed out and increased by 100 RPM in gear and milage went up 1 1/2 MPG in 300 miles. $12.00 a gallon at Wal-mart. It also lubes the fuel system and cleans combustion chamber and valve deposits.
Old Sep 23, 2008 | 05:52 PM
zman17's Avatar
zman17
Yes I do plan on still using the Techron.
