oil pressure
Old Sep 22, 2008 | 04:08 PM
dodgeram07's Avatar
dodgeram07
Exclamation oil pressure
How much oil pressure do you guys have? or how much should i have? i have a 95 5.2 and it always has 40psi or less after it gets warm. i will have a little bit ove 40 when its cold but when it get to about 180 it drops down (i would think i would drop but not whole alot). It floats around when its warm, sum times at idle it will be 40 if i'm luckLy most of the time less. so when i take off the pressure will go down, is this right? will try to get a pic to show.... and yes i did search and all i found was 40psi at idle.... any input at all would be great.. thank you.
Old Sep 22, 2008 | 04:12 PM
dillonjm's Avatar
dillonjm
At cold idle, mine is around 45, warm idle around 35.
When driving its above 40.
All of this of course is read off the factory "dummy" gauges.
Old Sep 22, 2008 | 04:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I don't think you have a prob, those pressures are around normal. Want to make sure? Change the sending unit or put in an aftermarket mechanical gauge and sending unit.
Old Sep 22, 2008 | 05:20 PM
dodgeram07's Avatar
dodgeram07
here is were it stays most of the time, when im picking up speed off a stop light, so at a stop light it will be little less than 40 then when i put the gas to take off it will drop down to this point ,,you guy are problemly right it maybe right
Old Sep 22, 2008 | 05:27 PM
dhvaughan's Avatar
dhvaughan
that's the same place mine reads, just under 40, most all the time. its normal.
Old Sep 22, 2008 | 05:36 PM
dodgeram07's Avatar
dodgeram07
well thank you guys, and thank you for posting back so fast...
Old Sep 22, 2008 | 07:06 PM
motorbrreath's Avatar
motorbrreath
you check your plenum gasket recently? i was runnin around that with a blown one until i put the m1 intake on it. Now it holds steady right at 40.
Old Sep 22, 2008 | 07:20 PM
dodgeram07's Avatar
dodgeram07
Originally Posted by motorbrreath
you check your plenum gasket recently? .
about a month ago, see it was weird it was very very dirty but i didn't see standing oil and i did that vac test were you block off the both sides of the pvc vale and take the breather hose and it was blowing not sucking so i don't know if it good or bad???? did i check it right??? but your right i need to check
Old Sep 22, 2008 | 07:37 PM
dhvaughan's Avatar
dhvaughan
i don't think a plenum would have anything to do with oil pressure. oil pressure is a measurement of the oil pressure that's output from the oil pump, as its pressurized against the oil journals (which are controlled leaks). so pressure can vary based upon pickup tube, oil pump, crank and cam bearing wear, similar ports in the valve train, oil filter, etc.
a leaking plenum might suck oil out of the crankcase, but i don't see how that would affect oil pressure at all.
Old Sep 22, 2008 | 08:21 PM
motorbrreath
yeah i understand that vaughan. i just figured id throw that in there since it did change after elimination of the plenum gasket.
i was always told it will sit a little lower at idle and jump up a hair under acceleration.
