Steering Problem, Where to look?
Old Sep 25, 2008 | 01:21 PM
RamWood's Avatar
RamWood
Default Steering Problem, Where to look?
The best way that I can describe the way the truck handles is:
You know when you are going down a gravel road in a car and you can sway the steering back and forth to wiggle the back end?
That is how my truck feels going down a paved road when driving if I wiggle the steering.
I just recently replaced the Tie rod and the Track bar (both Moog Lifetime parts)
I am thinking maybe tightening the steering?
any help is appreciated.
Old Sep 25, 2008 | 06:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the intermediate shaft from the steering box to the steering column going into the firewall and make sure there is no play there or at the slip joint also.
Old Sep 26, 2008 | 10:09 AM
RamWood's Avatar
RamWood
I will check that today thanks for the idea
Old Sep 26, 2008 | 08:14 PM
dodgeguy97's Avatar
dodgeguy97
i would and will recomend this to everyone who has a 94-01 dodge ram to fix the bushing in the lower steering column nobody even thinks of this as a problem but it is i just replaced and fixed mine feels like it did brand new go to www.rocksolidramtrucksteering.com $59.50 out the door
Old Sep 30, 2008 | 09:28 AM
RamWood's Avatar
RamWood
how would I be able to tell if this is the problem?
will there be play in the piece?
I don't want to fix what might not be broke
Old Sep 30, 2008 | 06:10 PM
zman17's Avatar
zman17
Just grab the column where it comes out of the fire wall under the brake booster and see if it moves around at all. And about 16 "s or so ,towards the gear box you will see the slip joint. BTW, You should have someone in the truck and have them turn the wheel from left to right and look at all the steering and suspension parts to see if anything is loose.
Old Oct 2, 2008 | 12:33 AM
dodgeguy97's Avatar
dodgeguy97
at the end of the steering column where the shifter bracket is and the inner shaft comes through it grab hold of the inner shaft (this sounds sexual lol) and see if it moves side to side if so the bushing is worn out chrysler builds there columns loose on the 2nd gen rams and they just get worse as years and miles go buy
Old Oct 2, 2008 | 08:11 AM
RamWood's Avatar
RamWood
10 4 I will check that also when I get home
